ironhead help needed : V-Twin Forum: Harley Davidson Forums
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > Technical Discussion Forums > Pre-Evolution Engines
Old 12-14-2012, 11:41 AM   #1 (permalink)
chaz851 wants to know Dino or Syn?
just restarted the project. think we have a 72 motor in a 1978 frame.so should work??
the motor is 4D52318H2 .
what I would like is if someone could take a couple of pictures for help please.
firstly .. removed oil tank . I need to see how the tank is fitted which brackets am I missing?
secondly.. with chain cover removed, I need to see the ? chain oiler pipe layout, where should it run to clear the chain and where is it secured to, also I can see the two engine oil line outlets but what is the large threaded spigot underneath from gearbox? is it speedometer as front wheel has speedo drive in?? many thanks
either post the pics here or pm me an email address and will look that way.
chaz851 is offline   Reply With Quote Quick reply to this message
Old 12-14-2012, 07:20 PM   #2 (permalink)
Nitram_b4's Avatar
are you talking about just in front of (item 3 check valve) that is a location for a pressure switch or gauge on the oil pump?
Nitram_b4 is offline   Reply With Quote Quick reply to this message
Old 12-16-2012, 04:52 PM   #3 (permalink)
no, that switch is fitted, the one Im asking about is approximately where no1 is ,directly under the vee about the same level as 1 but has an external thread around 3/4" x 20tpi at a guess with what looks like a speedo drive in the centre,which is why Im asking if speedo I also have one on the front wheel.
Old 12-16-2012, 07:02 PM   #4 (permalink)
Nitram_b4's Avatar
I think you may be right, mine was off the front wheel tho
On Sportsters up until and including 1972, the speedometer drive runs off the countershaft low gear in the transmission. The drive is a round insert through the transmission casing with a beveled rotating gear on the end that meshes with the low gear. A cable is attached which of course goes to the speedometer. The speedo drive gear rotates the inner part of the cable, which rotates the mechanism in the speedo head to operate the odometer and speedometer.
Old 12-18-2012, 04:07 PM   #5 (permalink)
thanks for that, seems like they had an option for speedo drive from either or place then. as its in direction of travel seems an ideal spot for dirt to get in. unless there is some sort of cover missing.
still need a picture of oil tank brackets
Old 12-18-2012, 04:30 PM   #6 (permalink)
Nitram_b4's Avatar
https://www.denniskirk.com/speedomet...72.p273165.prd
the plug you are looking for
Old 12-18-2012, 04:37 PM   #7 (permalink)
Nitram_b4's Avatar
lower oil tank bracket
http://www.jpcycles.com/product/740-598
Old 12-18-2012, 05:32 PM   #8 (permalink)
thanks again,
the blanking plug also has a male thread, the one out of the engine is male as well. the bracket looks like one I have but painted. will have to re check how its fitted.
