wow how do i repair a spark plug hole in my cylinder head : V-Twin Forum: Harley Davidson Forums
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > Technical Discussion Forums > Pre-Evolution Engines
Old 07-19-2012, 07:46 PM   #1 (permalink)
spark plug wants to know Dino or Syn?
wow how do i repair a spark plug hole in my cylinder head priced a new and you have to purchase a pair which is roughly $1,300 is there an efficient way to repair them?
spark plug is offline   Reply With Quote Quick reply to this message
Old 07-19-2012, 08:14 PM   #2 (permalink)
not sober all the time
Uncle Salty is reading this now saying WTF is this? Uncle Salty is reading this now saying WTF is this?
I imagine a TIME-SERT would be a decent repair. Also a machine shop could repair it.
Uncle Salty is online now   Reply With Quote Quick reply to this message
Old 07-19-2012, 08:55 PM   #3 (permalink)
1bdBagr is reading this now saying WTF is this?
Used take-off heads are plentiful too.
1bdBagr is online now   Reply With Quote Quick reply to this message
Old 07-20-2012, 06:34 AM   #4 (permalink)
NJ Rider's Avatar
NJ Rider wants to know Dino or Syn?
There are repair kits for that. If I'm not mistaken, it has a tap and an insert.
I don't remember if the spark plug hole has to be drilled oversized for the insert, but
grease the tap well (to keep metal flakes from falling into the cylinder), tap the hole and install the insert.
NJ Rider is offline   Reply With Quote Quick reply to this message
Old 07-20-2012, 06:49 AM   #5 (permalink)
kustom_flames's Avatar
kustom_flames is reading this now saying WTF is this?
I just did this in my 65 Chevy with aluminum heads. I first bought a cheapo rethread kit at FLAPS for $30. Didn't take. Use the Time-Sert! Because my first one did not take, the time-sert didn't work for me, so I used the next one up - Big-Sert. This if for the second tapping. I also used a product called Rapid-Fix to adhere it to the head. It is a 2 part system with a bonding agent and a 'welding powder'. So far has held up quite well...
Of course a used takeoff head might be the way to go...time-sert kits are about $150 or so...
Sold!
kustom_flames is offline   Reply With Quote Quick reply to this message
Old 07-20-2012, 08:48 AM   #6 (permalink)
jammer45u's Avatar
jammer45u is reading this now saying WTF is this? jammer45u is reading this now saying WTF is this?
Heli-coil will do the job. Get them at any good automotive store, reasonable cost.
jammer45u is offline   Reply With Quote Quick reply to this message
Old 07-20-2012, 08:51 AM   #7 (permalink)
I feel a time sert is the best option.. The heli coils are not a long lasting item when compare to the time sert. There are complete kits for your application..
Old 07-20-2012, 09:53 AM   #8 (permalink)
nortster wants to know Dino or Syn?
Depends on your compression.
Had a bud with a high compression shovel, blew out the insert.
Lower compression, the insert probably would still be working just fine.
Dan Quayle does my spellchecking
nortster is offline   Reply With Quote Quick reply to this message
Old 07-23-2012, 01:18 PM   #9 (permalink)
Scooter wants to know Dino or Syn?
How bad is it? My rear (pan) head is a little corrupt. Everytime I remove the plug I have to chase the threads with a spark plug hole thread chaser that I've had for years. You can probably pick up a thread chaser and try that first. Been babysitting this marginally threaded head for years without having to do a major repair.
Scooter is offline   Reply With Quote Quick reply to this message
Old 07-23-2012, 06:01 PM   #10 (permalink)
LowRiderCustom wants to know Dino or Syn?
I bought a nice tap with solid inserts on Ebay for around $30 and it worked great on the stripped spark plug hole on my daughter's car. I put thick grease on the tap to stop the metal shavings from going into the cylinder and I didn't have to pull the head.
LowRiderCustom is offline   Reply With Quote Quick reply to this message
Old 07-23-2012, 09:04 PM   #11 (permalink)
Larbaldi's Avatar
Larbaldi wants to know Dino or Syn?
Time Sert is one of the best options ... while many others work I think this is the way to get it done. Good Luck with your repair.
http://www.timesert.com/html/sparkplug.html
Black Bikes Matter
2009 FLHTCU ( BLACK, OF COURSE ! )
1979 FXEF STROKER ( BLACK, OF COURSE ! )
BUSHTEC QUANTUM TRAILER ( BLACK, OF COURSE ! )
AMA MEMBER / ABATE MEMBER
Larbaldi is offline   Reply With Quote Quick reply to this message
Old 07-23-2012, 09:10 PM   #12 (permalink)
Any solid insert will work, it doesn't have to be a $150 time sert. I'm a tool & die maker/machinist so I know they are all the same.
Old 07-24-2012, 12:31 AM   #13 (permalink)
Nahanhoku wants to know Dino or Syn?
I am with Scooter. If the threads aren't too bad, you can chase them with a spark plug threader. Thread it until you feel moderate resistance then bring it back out and clean the residue off the tool and start again. Then if that doesn't work, tap and use an insert or heli-coil.
Nahanhoku is offline   Reply With Quote Quick reply to this message
Old 11-12-2012, 11:38 AM   #14 (permalink)
panman69 wants to know Dino or Syn?
I have a insert in my front pan head, high compression, the problem is there was/is an oil galley next to the plug hole and the insert got into the oil galley and I had oil coming out of my spark plug hole inside and out.
panman69 is offline   Reply With Quote Quick reply to this message
Old 11-12-2012, 12:50 PM   #15 (permalink)
HATER OF THE GRAVEL!!!!!!
Jeffytune's Avatar
Jeffytune is reading this now saying WTF is this?
Okay, here is how to repair it correctly.
1) Remove the head.
2) Take it to a quality machine shop and have them fix it.
3) Reinstall the head.
I'm Just Sayin'...
2010 FLHTCUI
96 CID w/ the quiet 6 speed
K&N RK-3930 air filter
Harley quiet high flow 110 mufflers
Vance and Hines Fuelpak
Professional Rockat Surgen
Disclaimer.
Jeffytune is offline   Reply With Quote Quick reply to this message
