Shovelhead crankcase pressure : V-Twin Forum: Harley Davidson Forums
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > Technical Discussion Forums > Pre-Evolution Engines
Old 03-10-2011, 04:10 AM   #1 (permalink)
unclebill wants to know Dino or Syn?
Unhappy Shovelhead crankcase pressure
Hi there wonder who may have some advise, I have a 1980 FLT Shovelhead, seems to be a lot of pressure coming out of the crankcase vent. blowing oil out ...why what and what to do about it
Thanks Uncle Bill
unclebill is offline   Reply With Quote Quick reply to this message
Old 03-10-2011, 07:03 AM   #2 (permalink)
155" R&R TwinCam
dog155's Avatar
dog155 wants to know Dino or Syn?
If the bike has been sitting a while and first starting it's common for them to puke a little oil.It will stop very quickly,other than residual oil dripping out of the breather pipe.It's excess draindown oil in the crankcase and the engines way of clearing it's throat so to speak.
dog155 is offline   Reply With Quote Quick reply to this message
Old 03-10-2011, 03:07 PM   #3 (permalink)
run engine
when you say stop quickly.... please explain... I rode it a few miles and a lot of the oil was blown out... onto the rear tyre.... slippery as ice ...have maybe ran the engine for a total of 2 hours
Bill
Old 03-10-2011, 09:39 PM   #4 (permalink)
Larbaldi's Avatar
Larbaldi wants to know Dino or Syn?
Thanks Uncle Bill
There is a "fix" to the oil bleeding into the crankcase ( which causes the condition you are experiencing .. known as blowby ) after sitting for a long period of time. Stop by the HD shop and get a new check ball and spring ( some guys get two check balls ... they take one and use a hammer and drift and give the check ball a "love tap" to reshape the seat in the pump housing then remove the ball and place the new one along with the new spring ) . This is a quick and easy repair. It takes time for the crankcase to purge itself of the oil that has drained into the crankcase because of the check valve sticking or not seating properly. Start the engine and let it run at idle for a while with a drain pan under the crank case vent line. This may take a bit of time but it will eventually purge itself of excess oil. Hope this helps!
Black Bikes Matter
2009 FLHTCU ( BLACK, OF COURSE ! )
1979 FXEF STROKER ( BLACK, OF COURSE ! )
BUSHTEC QUANTUM TRAILER ( BLACK, OF COURSE ! )
AMA MEMBER / ABATE MEMBER
Larbaldi is offline   Reply With Quote Quick reply to this message
Old 03-10-2011, 10:12 PM   #5 (permalink)
springer-'s Avatar
I personally do not perscribe to the hammer and ball method for working on oil pumps. Here is an alternative method.... http://www.bigboyzheadporting.com/showthread.php?t=87
Check out Ride of the Month
207-621-8089
Old 03-11-2011, 10:10 AM   #6 (permalink)
Larbaldi's Avatar
Crankcase Blow By
Here is a link to an illustration of the oil pump. The ball, check valve and spring are numbers 18, 19 and 20. http://demonscy.ipower.com/manuals/s...mp_68-84_1.jpg
Springer has also provided you with a link that offers a good solution. The procedure that you follow will obviously be based on your mechanical abilities. As I stated earlier the oil leaking/spewing out of the breather should subside after a few minutes of idling. If this continues you are going to have to look further for a cause.
Black Bikes Matter
Old 03-11-2011, 12:49 PM   #7 (permalink)
cracker III wants to know Dino or Syn?
All the above fixes are for a situation called "wet sumping". This is basically oil bleeding back by the check ball (in the oil pressure system) and filling up the crank case after moderate to long periods of sitting.
These are solutions to that problem... but I don't think they are answering your question.
Your question is in regards to the source of pressure... specifically crank case pressure... and what and when to do something about it. Yes? (Or maybe I don't understand)
Assuming I do, I will go with the following:
How much blow by is normal? Dividing an engines maximum horsepower output by 50 will give you a ballpark number for how much blow by you would normally expect to see. For example, a street performance engine that makes around 500 horsepower will typically have about 10 cfm of blow by with conventional pistons rings and ring end gap tolerances. Higher performance engines that are built to tighter tolerances will usually have less blow by, as might those with gapless piston rings. An 800 to 900 horsepower NASCAR motor, for example, might only have 5 cfm of blow by.
Less blow by means more usable horsepower. Being able to baseline the actual blow by in an engine means you can then go back and try different ring configurations, ring types (conventional or gapless), different ring end gap settings and cylinder wall finishes to see which combination gives the best seal and the least amount of blow by.
Measuring blow by has been one of the best kept secrets with performance engine builders because it allows them to see how well the rings are or are not sealing. It also allows them to detect any ring flutter that may be occurring within a particular rpm range, and to then change the mass or end gaps of the rings to minimize the problem.
Keep in mind that this is not PSI… it flow… and you will need a flow meter (or the like) to measure CFM.
cracker III is offline   Reply With Quote Quick reply to this message
Old 03-12-2011, 08:35 AM   #8 (permalink)
Dan89FLSTC wants to know Dino or Syn?
Make sure all oil return lines are clear and not kinked.
Check to be sure that oil is being returned to the tank.
Make sure you are using the correct oil filter.
Dan89FLSTC is offline   Reply With Quote Quick reply to this message
Old 10-30-2014, 07:24 PM   #9 (permalink)
Tombsycles wants to know Dino or Syn?
Amazingly, after 40 year of "hands-on" experience, I have the same issue with a 1200 FXE. Fresh built engine. New (correctly installed) S&S oil pump. It's puking oil onto the floor while parked. The engine case is filling up with oil coming from the tank/bag.
WTF?
Tombsycles is offline   Reply With Quote Quick reply to this message
Old 10-30-2014, 07:50 PM   #10 (permalink)
Viel Vergnügen
vindex1963's Avatar
WTF?
Welcome to the forum.
2015 Victory Cross Country
Old 10-30-2014, 11:08 PM   #11 (permalink)
springer-'s Avatar
WTF?
Check out my link above in post #5, that was a brand new S&S pump with the same issue.
207-621-8089
