Backfiring through S&S carb : V-Twin Forum: Harley Davidson Forums
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > Technical Discussion Forums > Pre-Evolution Engines
Old 09-22-2009, 11:09 AM   #1 (permalink)
JoeShovel's Avatar
JoeShovel wants to know Dino or Syn?
OK, 1966 74" shovelhead with Mallorery electronic ign, S&S super E shorty carb...
Was running fine with no problems at all and now it is backfiring through the carb very badly. Feels like one cylinder is not firing at all. This all started after I went to the gas station and put in lower octane due to them not having higher octane.
Here is what I have done so far to no avail:
I have drained out all of the bad gas from the tank and carb, put new plugs in, verified that I'm getting spark to the bad cylinder, adjusted timing...
I'm at a loss at this point. Every electronic component was replaced and rebuilt over the summer so I'm only left to think it is a mechanical issue which I hope it isn't.
Any thoughts?
1973 FX frame chopped in the rear with rigid welded in place. Bottom end is 58 panhead topped with 66 shovelhead. S&S super E carb, Andrew B grind cam. 73 4spd trans. Kick and Electric start... A bobber fo sho
JoeShovel is offline   Reply With Quote Quick reply to this message
Old 09-22-2009, 11:25 AM   #2 (permalink)
XLIII
MegaGlide's Avatar
MegaGlide wants to know Dino or Syn?
Are the plug wires new?
If not, check to see if the one going to the non-firing cylinder is rubbed through somewhere and shorting intermittently as the engine vibrates.
Dave
Snarkiness without knowledge is, well, just sad, really.
Sherlyn Popelka DUI, Aggravated Assault, Fugitive Arrest Reports HERE:
http://www.sherlynpopelka.net/
MegaGlide is offline   Reply With Quote Quick reply to this message
Old 09-22-2009, 11:28 AM   #3 (permalink)
Waffen's Avatar
Waffen is reading this now saying WTF is this?
Manifold leak, carb jets plugged up with some debris.
W
Waffen is offline   Reply With Quote Quick reply to this message
Old 09-22-2009, 11:35 AM   #4 (permalink)
JoeShovel's Avatar
W
How would I go about cleaning this?
Old 09-23-2009, 09:54 AM   #5 (permalink)
NAPA sells a good carb cleaner kit. Very agressive cleaning solution.
Scott
Old 09-23-2009, 01:04 PM   #6 (permalink)
Waffen's Avatar
First to the manifold. If you can get it running, spray some WD40 where the manifold is bolted to the jugs. If you notice a change in idle or how it runs you may have a leak which creates a lean environment which you experience as the backfiring through the carb.
To clean the carb, personally I think it's best to take it off the bike, pull it apart and clean it throughly and don't forget to check the float.
I don't know your carb specifically but you should be able to find a manual showing the schematics which will help. Also if you do take the carb apart it might be a good idea to change the o rings and gaskets.
W
Old 09-24-2009, 08:48 AM   #7 (permalink)
JoeShovel's Avatar
Could anything else besides this create a backfire though.... I guess I'm just worried that I have a stuck valve or something...
I was informed that:
backfire though pipes = carb
backfire through carb = ignition.
Is this true?
Old 09-24-2009, 12:12 PM   #8 (permalink)
Waffen's Avatar
backfire though pipes = carb, Rich condition to much gas valves possible
backfire through carb = ignition. Lean condition, leak, plugged jet, jetted incorrectly and quite possibly ignition.
Is this true?
Timing might also be off.
W
Old 09-24-2009, 02:12 PM   #9 (permalink)
JoeShovel's Avatar
W
Ok, this is something I was also thinking but should I advance or retard...?
I would think by retarding it, it would still be too lean if that is the case.
Old 09-24-2009, 07:07 PM   #10 (permalink)
OUCH! That hurt
wfolarry's Avatar
wfolarry wants to know Dino or Syn?
Putting in 87 octane could make it backfire as it would appear to be lean. Putting premium in should have solved this. Did you do anything else [play with timing, jets etc.] when it was backfiring to try & correct it before you took it apart?
38 years of ridin' & wrenchin'
wfolarry is offline   Reply With Quote Quick reply to this message
Old 09-28-2009, 10:41 AM   #11 (permalink)
JoeShovel's Avatar
Well it was 89 octane that I put in it and drained it all out and put in fresh 93. Now, when I was stuck on the side of the road I did play with timing but have since put it back to where it was. It is very hard to start now. Have not had the time to play with it that much this weekend. Hopefully more this week since it is going to be nice.
Old 10-01-2013, 07:20 AM   #12 (permalink)
Ltsulli1 wants to know Dino or Syn?
Check to make sure your stator and rotor is charging the bike... With the bike running put a meter on your battery and rev it up to about 2k rpm watch the meter and make sure the voltage spikes up to around 12.9vdc if it doesn't move then your stator is bad or your regulator... No way to test regulator but you can test the stator by pulling the plug off the motor where the regulator plug into it.... You should have continuity between both posts of stator... Then each post to ground should have no continuity if it does anything different your state or is bad! Good luck
Ltsulli1 is offline   Reply With Quote Quick reply to this message
Old 10-01-2013, 09:28 AM   #13 (permalink)
springer-'s Avatar
This thread is 4 years old. I hope he has it fixed by now.
Check out Ride of the Month
207-621-8089
Old 10-02-2013, 09:14 AM   #14 (permalink)
But there are always people with simalar problems just hoping to help the next person is all!
Old 10-19-2013, 06:09 AM   #15 (permalink)
Billyroyjoebobj wants to know Dino or Syn?
new to forum, Your exactly right about others having this problem. It is the same thing i've been going through. Differences are I built my bike to look like a '58. It's on a '66 frame ('53 fle w/std heads & s&s super e. Thanks for tips. will get on with it this weekend.
Billyroyjoebobj is offline   Reply With Quote Quick reply to this message
