1980 WideGlide Carb or some weird electrical problem? : V-Twin Forum: Harley Davidson Forums
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > Technical Discussion Forums > Pre-Evolution Engines
Old 07-17-2008, 11:03 AM   #1 (permalink)
Lothos wants to know Dino or Syn?
Bike was running great on Tuesday. Rode 20 miles just fine then poof ran out of gas. Put some gas in and it would turn over but not fire. Tried to jump it through the clips off the battery tender but it wouldn't get any spark and the battery got hot. Got a new battery, started right up. Every time I run it now though I get a mile or so and it acts like it's out of gas. Turns over, won't fire. Been sitting a bit while waiting for some parts. I figure it's the carb and was going to rebuild it (S&S E). The battery acting up made me possibly think there's some weird short too but can't see how that's related to how it's acting now.
Lothos is offline   Reply With Quote Quick reply to this message
Old 07-17-2008, 12:15 PM   #2 (permalink)
Highly Seasoned Rider!
newultraclassic's Avatar
newultraclassic wants to know Dino or Syn?
At the risk of getting attacked, I will say that in my opinion, the S&S type carburetors are not the easiest starting carburetor on a Shovelhead. I expect to be attacked and drummed out of the internet community for that, but I won't retract that statement.
It's possible that your fuel tank is clogged with old Kreem flakes or rust particles. I would remove the petcock and see if it isn't clogged. That's not uncommon for older bikes.
A CV carburetor would be a good choice to replace your S&S. The problem with both the original side-draft Keihin and the S&S is that they let too much air in when starting the engine. The CV is much tighter what with its diaphragm and the slide closing at start up.
It almost sounds like you have two different problems. First, if you have a weak battery.....well, you have a weak battery, You must understand that a Battery Tender will only put out at the most about an amp and a quarter. They are not a battery charger or a battery jump start device. They are for like overnight or longer recharges and maintenance.
As to the possibility of a parasitic short, you can check that with an accurate ammeter, one that can read down to a milliamp range. Just park the bike, remove either battery cable (positive is ieasier to reach on a Shovelhead) and see if there is a current drain. Even one of 50-100 milliamps (1-20th to 1/10th of an amp) will drain a battery down over a day.
If you have a short such at this, then it's time to start looking at both ends of each wire in the loom with a good voltmeter. There should be no grouinding pathe from any wire to the frame. You can check continuioty from end-to-end on a wire and from one end of the wire to the frame. I once had to do every last wire in my Shovlehead to find a short in one of the connectors inside of the headlight. I finally re-wired the whole bike to simplify the wiring but it drove me nuts finding it the short.
The S&S is a nice carburetor for drag racing. For starting and cruising, there are better choices. Anything with a slide would be my choice. CV or Mikuni would be OK.
S&S carbs sell nicely on eBay, too.
newultraclassic is offline   Reply With Quote Quick reply to this message
Old 07-17-2008, 12:27 PM   #3 (permalink)
Agreed on the tanks. I was gonna check there and check the fuel lines, petcock etc to see if it was being clogged. And yeah, kinda think I have two problems. Not positive I have a short, could have just been that was all she wrote for that old battery. I think a cell went bad or something. It was a 2003 battery. The S&S came on it, I have a stock carb on my Evo but never tried one on my Shovel to compare it.
Old 07-17-2008, 02:08 PM   #4 (permalink)
Ok it's not a fuel problem. Pulled the hose off the carb and turned on the petcock, ran through great. Nothing nasty coming through. Carb is pumping gas through fine it seems. Jet of gas is hitting the butterflies. Floats or a rebuild of some other parts? I know some about carbs but not much. My other bike's carb had few problems so I didn't learn much from it.
Old 07-17-2008, 04:55 PM   #5 (permalink)
Checked the plugs and they were fouled. Got new ones, new wires no spark. The coil was replaced only a few weeks ago.
Old 07-17-2008, 05:33 PM   #6 (permalink)
baggersport's Avatar
baggersport wants to know Dino or Syn?
Ignition?????
What's under the "Points Cover"??
Still got the stock electronic, or has it been upgraded (lol) to a points and condenser??
Big Boyz Street Heads
207-242-8374 Cell Phone
207-621-8089 Port/Dyno Shop
baggersport is offline   Reply With Quote Quick reply to this message
Old 07-17-2008, 06:04 PM   #7 (permalink)
Crane Cams Hi-4. I've been checking for loose wires and all that. So much fun.
Old 07-17-2008, 10:23 PM   #8 (permalink)
Otto wants to know Dino or Syn?
i would be susect of the HI-4 I have seen way to many fail they are a good system when they work. I won a national championship in 96 running one but they have been known to fail. 3 this year i have replaced. or it could just be a terminal or breaker under the dash have replaced breakers before from heat failure and old age
Otto
my opinions are mine and subject to my way of thinking disagree if you will or not
Workin to play
Otto is offline   Reply With Quote Quick reply to this message
Old 07-18-2008, 10:37 PM   #9 (permalink)
The HI-4 has a red timing led on it that doesn't light when I crank it. Has me suspecting that or the coil as well. What coil and ignition is more reliable? How about the MSD or Accel ones?
Old 07-18-2008, 11:35 PM   #10 (permalink)
Y2K
Y2K wants to know Dino or Syn?
Pretty hard to beat Dynatek
http://www.cas4.com/Electrical-Ignit...ters-dyna.html
Y2K is offline   Reply With Quote Quick reply to this message
