SportbikeTrackGearRosa's CycleWheeldock.comHD PipesRacerPartsWholesaleProCharger.comKewlMetal.comMean City CyclesCheapCycleParts.comArnottAirRide
Go Back   V-Twin Forum : Harley Davidson Motorcycle Forums > Technical Discussion Forums > Pre-Evolution Engine Technical Discussions
Motorcycle.com Classifieds!
Old 08-26-2008, 09:34 AM   #1 (permalink)
JoeShovel's Avatar
JoeShovel is on a distinguished road
Air pushing through air cleaner...
What happens is, it sounds like air is pushing out of the filter, she will run and then a loud pop of air and then idle is fine. This is just when first starting up and the choke is pulled. Any thoughts? Doesnt seem to be a big problem but being very new to bikes and v-twins, I just want to make sure I'm not doing something wrong.
Spec's are in sig.
Thanks,
1973 FX frame chopped in the rear with rigid welded in place. Bottom end is 58 panhead topped with 66 shovelhead. S&S super E carb, Andrew B grind cam. 73 4spd trans. Kick and Electric start... A bobber fo sho
JoeShovel is offline   Reply With Quote
Old 08-27-2008, 09:21 PM   #2 (permalink)
cat5752 is on a distinguished road
My 85 FXRS with an S&S Super E does that every once in a while. I believe the technical term is called a carb fart. I haven't had any problems with it. I think sometimes I give it too many throttle rolls before punching the button. And if you have the same carb, you don't really have a choke so much as a enrichener. If you had a choke, like on a Bendix carb, a butterfly valve would close when you engaged the choke and you wouldn't have this problem as much. That's my opinion, FWIW. I have a 75 Sporty with a Bendix, and it has never popped back out the air cleaner. I think that the S&S Super E is prone to do this because it doesn't have that butterfly that closes off the air intake like a normal choke would/does. Hope this makes sense, and helps. Bottom line; I wouldn't worry about so long as your timing and jetting on your carb are correct.
cat5752 is offline   Reply With Quote
Old 08-28-2008, 09:52 AM   #3 (permalink)
JoeShovel's Avatar
Yup, makes perfect sense I think you are completely correct. She is a kick start as well so I have been practicing kicking her over since there is a damn nack to it for sure. So, I think when I go to kick it over I'm opening the throttle by accident due to weight transfer. It doesn't happen all the time.
