Originally Posted by the_roadking
Parts numbers, anyone?
From an OEM perspective...
There are almost 70 seperate part numbers for the hand shifter assembly and related trans/drum parts... the foot (rocker) clutch assemby lists another 35 parts.
You'd be better off looking at some of the aftermarket kits... like J&P 22-0720, or 22-1016, 15-908, 15-909, etc...
Of course the early shifter drum (cam & cover assembly) will be somewhat harder to find (OEM # 34801-65) as I'm not aware of any aftermarket source.
You might want to keep your "ratchet top" and go with the appearance of the old tank shift, but it'll really be a "slap shift" with the same pattern as the foot shift... see J&P # 22-0703... It would take some creative modification on your part to interface with the tank shift assembly, but it could be done.
Your only limits are your imagination... and your wallet.
