Single or dual with dual plug heads? : V-Twin Forum: Harley Davidson Forums
Old 07-09-2006, 05:37 PM   #1 (permalink)
VENJEFF is on a distinguished road
My tuning is now down to ignition. Im going to step away from the point set-ups this time and order a new ignition with no clue of what to get. Its basically stock FL shovel with dual plug heads and only running single plugs. What would be the best value in an ignition and coil or coils? Dual or single fire for my application? Different plugs? I want the basic, proven set up. Getting closer..... Jeff
VENJEFF is offline   Reply With Quote
Old 07-09-2006, 10:34 PM   #2 (permalink)
Highly Seasoned Rider!
newultraclassic's Avatar
If there is a choice, the single fire is had to beat. It cured a lot of problems in my stock Shovelhead. I run single fire Spyke with a matching 80KV coil, resistor plug wires as recommended and also AC Delco R44LS plugs. The ignition is just excellent.
Old 07-10-2006, 02:25 AM   #3 (permalink)
Acquisitions
dynageno's Avatar
dynageno is on a distinguished road
We run the dyna 2000i ignition (single fire) with a dual fire crane coil! Had it for a couple of years now-works great!
dynageno is offline   Reply With Quote
Old 07-10-2006, 12:25 PM   #4 (permalink)
The coil or coils I cant find for dual plugs in a kit. Whats the set up for coils? Please tell me I dont have to spend 500 bucks for all this. Jeff
Old 07-10-2006, 02:09 PM   #5 (permalink)
Thanks! I needed that.
Scabbydoo's Avatar
Scabbydoo is on a distinguished road
Had an XL1200S The stock set-up was twin plug, dual coil with single fire ignition. It worked great.
Scabbydoo is offline   Reply With Quote
Old 07-10-2006, 07:21 PM   #6 (permalink)
ROY YOUNG is on a distinguished road
You will have to run 2 coils with dual outlets for single fire dual plug heads. There may be someone now that makes a single package coil with 4 outlets. Crane makes a coil with 2 coils in a single package but last I knew, it only has 2 outlets and not 4. It is made for single fire with single plug heads. If you would like to see a wiring diagram, you can go to cranes web page and down load the installation instructions for the Crane Hi-4 single fire ignition. That is what I used 6 years ago and have not had the first problem. How much compression are you running? If it is a low compression motor, I wouldn't spend the money. If it is 9 or 10 to 1, it will be some of the best money you could spend.
ROY YOUNG is offline   Reply With Quote
Old 07-10-2006, 11:59 PM   #7 (permalink)
8 3/4 to 1, low compression. I already have dual plug heads installed and I need a complete ignition from new coil to advance unit anyway.(left the damn key on AGAIN !!). Thought I would upgrade now to electronic so when I leave the key on again, I will really be pissed.. I did find a Compu-fire set up as a complete package. Dual plug, single 4 output coil, single fire. Seems like a good choice unless anyone has had issues with it. I ride this about 20k a year. All the systems out there are spendy. I was hoping to get off alot cheaper than 350 bucks. Get what you pay for I guess. I spent 3 hours researching this stuff today and Im just as confused now as when I started. Probably why Im still running points.Jeff
Old 07-11-2006, 02:25 AM   #8 (permalink)
Ha, 8-3/4:1...that's not low. My Shovelhead has stock low compression pistons...7.4:1. Now that's low but I love it. Probably with 8 3/4 you can get by with only one plug per cylinder if you use mid-grade or premium. I can run the lowest grade available with my bike and at $3.30 a gallon for premium where I am, it's regular for me.
Old 07-11-2006, 09:43 PM   #9 (permalink)
Ive been running on 2 plugs for 64,000 miles now. Never could afford to upgrade ignition. Now Im fighting problems caused by me and think I want to upgrade now. Jeff
Old 07-14-2006, 02:13 PM   #10 (permalink)
RFORSE is on a distinguished road
I have been running a Crane HI-4 ignition and a Compufire 4 plug coil on my 81 FXE with dual plug heads for several years now and am having no problems. The compufire coil is 1 unit and puts out quite a spark. Believe me I know. I got a piece of it once and my arm hurt for a couple of days.
RFORSE is offline   Reply With Quote
Old 07-21-2006, 08:14 PM   #11 (permalink)
nauipro is on a distinguished road
Dyna makes an excellent 4 post single fire coil. Their part # is DC6-4. 3 ohms, will work with just about any aftermarket single fire ignition. The coil is carried by all of the major vendors.....Bill
nauipro is offline   Reply With Quote
Old 07-21-2006, 09:46 PM   #12 (permalink)
BryanL's Avatar
BryanL is on a distinguished road
I take it you're running Baisley heads? Why not give him a call and ask what he recommends. Even if Baisley didn't do the head work, you'll get a good answer for your setup
BryanL is offline   Reply With Quote
Old 07-22-2006, 03:12 AM   #13 (permalink)
Otto is on a distinguished road
my personal preferance would by a dyna coil and the DTT Ignition single fire mode with a voes and have fun
Otto is offline   Reply With Quote
