Lowrider transmission kicks into neutral when downshifting : V-Twin Forum: Harley Davidson Forums
Old 05-25-2006, 11:02 PM   #1 (permalink)
tractorhunter is on a distinguished road
Just got my new 1978 Lowrider on the road and noticed that when you downshift especialy into 2nd gear it seems to kick into neutral. If you rev up the motor a couple times it will kick into gear. All the gears seem ok and it upshifts fine. Any ideas of what is going on? thanks, TH
You are young, my son, and, as the years go by, time will change and even reverse many of your present opinions. Refrain therefore awhile from setting yourself up as a judge of the highest matters.
Plato, Dialogues, Theatetus
tractorhunter is offline   Reply With Quote
Old 05-26-2006, 02:15 PM   #2 (permalink)
80FXS80 is on a distinguished road
Since it's only occuring in one direction it is probably a bad shifter pawl in the ratchet top. (part of the indexing unit inside the stamped steel cover on the side of the ratchet top). There are seperate pawls for up and down shifting. Could be as simple as a broken spring in there. Very inexpensive fix. I was unable to find an exploded view of the mechanism. you'll need a parts book, or to go to the dealership to identify the specific part numbers.
80FXS80 is offline   Reply With Quote
Old 05-26-2006, 02:56 PM   #3 (permalink)
Thanks 80, The inexpensive part got my attention. I have the manual so I guess I'll be pulling my first transmission apart. Runs sweet and handles great, shame about this but if I didn't want to work on a bike I'd have a new lowrider or dyna. Thanks, let you know how I made out. TH
Old 05-26-2006, 05:30 PM   #4 (permalink)
ORIGINAL DOOF BABE
Lady Godiva's Avatar
Location: Hilton Head Island, SC (Formerly from Lansing, MI)
Lady Godiva is on a distinguished road
You might try searching on shifting into neutral or something similar - I know I saw a thread awhile back about a similar problem that ended up being something fairly simple & you might be able to get some other ideas. Good luck!
Laurie T.
2000 FLHRCI Road King Classic - 95" Big Bore
"I refuse to have a battle of wits with someone who's unarmed"
(and I have 43 points on the top of my head)
VTF Photo Album Link: http://www.v-twinforum.com/gallery/s...page=12&sort=3
Lady Godiva is offline   Reply With Quote
Old 05-27-2006, 10:11 AM   #5 (permalink)
Ok
Thanks Lady, I'll try that.
