runs rich, occasional backfire thru carb,sounds like pinging in rear cyl : V-Twin Forum: Harley Davidson Forums
Old 08-12-2005, 08:22 PM   #1 (permalink)
kickstartshovel is on a distinguished road
I have a 72 fx, fresh motor, 38mm bendix with an adjustable main, 1st. I was wondering if anyone had a starting point for the main jet adjustment , elevation here is 2500 ft.next is the motor runs exrtemely rich ,but I get a low speed to mid range backfire thru carb when she's warm. Finally I get a pinging noise in the rear cylinder at low speed, any help would be appreciated, I'm a fairly good tech but I think I need a fresh set of eyes on the problem , thanks for any suggestions
kickstartshovel is offline   Reply With Quote
Old 08-12-2005, 10:15 PM   #2 (permalink)
chopperb's Avatar
chopperb is on a distinguished road
check the timing and the plugs,wires and for at least 13.8 volts at the coil when running
chopperb is offline   Reply With Quote
Old 08-12-2005, 11:14 PM   #3 (permalink)
Thanks for the help bro,I'll let you know how it goes, Keep it on the wheels !
Old 08-13-2005, 07:46 AM   #4 (permalink)
PHUCKING BIKER!
tequacha is an unknown quantity at this point
what you running for a cam, what pipes?
Trailering your motorcycle, is a disease. For help dial 1 800 scared to ride
tequacha is offline   Reply With Quote
Old 08-13-2005, 09:31 AM   #5 (permalink)
andrews "J-grind" , dual exhaust, no crossover, thru 28" long FL style rocket mufflers
Old 08-13-2005, 10:43 AM   #6 (permalink)
The starting point on the adjustable main jet is 4 turns out....now thats going to be rich, to adjust it correctly the bike has to be at operating temp and in 2nd gear open the throttle wide open seee if the bike pulls good or breaks up. If it breaks up lean the jet by screwing it in 1/2 turn at a time and crank it open again in 2nd gear, continue this till the bike pulls smooth and strong. The timing has to be done correctly first. After you get the main jet done you can now adjust the idle mixture.
Doc
Old 08-13-2005, 04:55 PM   #7 (permalink)
chopperb's Avatar
Old 08-14-2005, 02:41 PM   #8 (permalink)
Shithead
petelogan's Avatar
petelogan will become famous soon enough
What the Doc said, but backfiring in the carb indicates lean, while you also say rich at more open throttle. Pinging is obviously lean.
Sounds to me like you're lean on the idle and rich on the main.
I think I would make double sure the timing is spot on, and then look to the carb.
I ain't a pro, though.
Pete
”This above all: to thine ownself be true,
And it must follow, as the night the day,
Thou canst not then be false to any man.”
-Shakespeare-Hamlet
"Generally speaking, you don't die on motorcycles.
You die a few yards away from what's left of them."
-Me
It appears I am not only a NRA Life Member, but also a Patriot Guard.
**** - I didn't know that
Holy Mololey, Batman, I didn't know I was a GOA Life Member, either
Being drunk seems to be better
petelogan is offline   Reply With Quote
