Teflon valve seals : V-Twin Forum: Harley Davidson Forums
Old 07-07-2005, 10:34 PM   #1 (permalink)
windsoreight is on a distinguished road
Teflon valve seals
I have my heads at the machine shop getting rebuilt. I bought a set of Crane teflon valve seals. The machine shop is telling me they are too tall. I have talked to 2 different motorcycle shop and got 2 different opinions. The first shop told me they will work fine. Just machine the height of the guide down. The other shop said they would not reccomend shortening the guide. They told me to get a different type of seal. Going to the Crane website their notes states thet the top spring may have to be removed. Has anyone run into this before? I don't see why shortening the guide would cause any harm. I am trying the get the bike together this weekend and if I can't get this straight it isn't going to happen. Thanks.
windsoreight is offline   Reply With Quote
Old 07-08-2005, 10:10 AM   #2 (permalink)
Highly Seasoned Rider!
newultraclassic's Avatar
I would certainly NOT shorten the valve guides in what I assume is a Shovelhead. They are already too short. You could always use the stock Harley seals. Although they look flimsy, they will last if installed properly. They will fit, too.
Shortening the valve guides will lead to early wear and shorter life.
Old 07-08-2005, 09:33 PM   #3 (permalink)
I went with the seal the machine shop reccomended. THey told me to get the steel seal with the teflon insert. So that is what I got and it works great. I am putting it together sunday so I will find out. THanks.
Old 07-09-2005, 11:18 AM   #4 (permalink)
Hope it works out for you.
