ProCharger.comDiamond Bar ChoppersMotorcycle.comStainless Ride Specialty Accessories
Leslie Kay's
Old 08-18-2004, 10:16 AM   #1 (permalink)
shoveleric is on a distinguished road
shovel smoking on rear cylinder
Just completed top end rebuild on my shovel, the front cyclinder runs very clean, but the rear is puffing a bit of white smoke and at times sounds like it might be missing occasionally. Don't really notice any problems under throttle - it seems to run strong, but I would like to get the rear to run as clean as the front cyl.
I've tried fresh plugs and swapping the the coil leads ... no difference.
Any ideas on what I should look at next?
Eric
shoveleric is offline   Reply With Quote
Old 08-18-2004, 10:19 AM   #2 (permalink)
GrayRider will become famous soon enough
You say it's puffing white smoke, I would think that would mean a valve was not seated, maybe?
If the rings weren't seated it would puff black/blue smoke.
GrayRider is offline   Reply With Quote
Old 08-18-2004, 10:45 AM   #3 (permalink)
Highly Seasoned Rider!
newultraclassic's Avatar
Eric
Did your valve guides have seals on them? It sounds like a seal is damaged if so....
Old 08-19-2004, 07:19 PM   #4 (permalink)
PHUCKING BIKER!
tequacha is an unknown quantity at this point
if you have 2 into 2 exhaust check for oily black ring on end of pipe usually indicates guide blowing oil by. also if plug is showing oil could be cylinder oil passage is leaking through head gasket
tequacha is offline   Reply With Quote
Old 08-20-2004, 02:51 AM   #5 (permalink)
Black smoke is from gas. White smoke is from antifreeze/water, which he ain't got. Blue smoke is from oil. He's probably seeing blue smoke.
Now back to the problem...........Is it smoking at idle and gear shifts, not under load? If so, you likely have a leak at a valve seal. It is common in Shovels/Irons. The miss is also something that is common on the rear cylinder on those bikes. Ride it for a while and check the plugs. If you don't have an oil consumption problem and the bike runs good, ride on and forget about it.
