S&S Super B adjustment : V-Twin Forum: Harley Davidson Forums
Old 07-22-2004, 10:35 PM   #1 (permalink)
red89yj wants to know Dino or Syn?
im running rich and know nothing about this carb. anyone know where i can get a downloadable or online manual for the thing?
i love the flames out of the pipes but the smoke is killing me and i have yet to hear what this bike sounds like w/ the choke off.
TIA-
RICH
1975 FLH w/ stroker 1200 (CI unknown right now)
red89yj is offline   Reply With Quote Quick reply to this message
Old 07-22-2004, 11:30 PM   #2 (permalink)
Hank85713 wants to know Dino or Syn?
take a look at:
http://www.sscycle.com/technical/instructionsheet.asp
Hank85713 is offline   Reply With Quote Quick reply to this message
Old 07-23-2004, 11:54 AM   #3 (permalink)
Ironbutt
MilesToGo's Avatar
TIA-
RICH
The Super B has an idle mixture adjustment located on top of the carb - it's the adjuster to the right of the choke. Try turning the idle mixture knob in (clockwise) a little. If that doesn't work you may need to try some different jets. You should also check your manifold intake seals. If the seals are shot or leaking you will run rich.
Old 07-23-2004, 01:23 PM   #4 (permalink)
72FX/04Ultra
fauskar wants to know Dino or Syn?
Check out sscycle.com
1) There's no choke. Only an enrichment device used for starting. Lift it up and rotate slightly to enrich the mixture and down to shut it off. Use to prime engine with ignition off. Can be left on temporarily with some open trottle, iginition on, during warmup.
2) Start with idle mixture set One and One half turns out from closed. And throttle sjustment screw out 1/2 turn. Do no over tighten to find closed position.
3) Start engine and run until oil and engine is warmed-up, and adjust throttle stop until you get 1000rpms.
4) Adjust idle mixture both in and out until engine begins to die. Put the idle mixture screw between those two points.
If the idle mixture screw has no effect, then your intermediate jet (IJ) may be to lean (small) or rich (big). If turrning the idle mixture screw in (lean) doesn't cause the engine to die, you have to big of a IJ. Stock IJ is a .028. Jets are avialable in ).015 increments. (25 being the lowest). Carb bowl must be removed to change IJ.
Hig
If you have an air leak, then the engine will run poorly at idle and higher
Klaatu barada nikto
fauskar is offline   Reply With Quote Quick reply to this message
Old 07-23-2004, 02:15 PM   #5 (permalink)
thanks a lot fellas. i downloaded and printed the manual from sscycle.com i went there before but the tech page wasnt loading, but that got taken care of. im gonna take the advice from you guys and ill be back to tell you how it went.
thanks again
Rich
