oil on plugs
Hi
Thanx for the info.
I got the 75fxe.
It does not smoke, it starts up ,I started it with kick and electric.
I rode it some Fri, I need to rebuild the brakes before I ride it on the road much.
It still has the dry clutch system, I have a Karata primary belt kit for shovels.
I would like to isolate the primary & install this kit later.
Right now works ok with the original set up, I don't like the clutch debris in the oil though.
Believe it or not it does not leak oil, it seeps some around the rocker boxes.
Is there a simplified written instructions for rebuilding shovels?
I will do this myself later.
D
