Engine vent question 55 Panhead
The vent outlet which is in the engine case, just above and inside the oil pump is usually vented to the top of the oil tank. The 55 Pan that I'm helping with, has an aftermarket oil tank which has no top of the tank place for the vent to attach. Where do you recommend that this vent be routed.
