Motorcycle.comCycleGear.comDan Vance RacingPro Pad
Leslie Kay'sRRcycles.comMotorcycle-Communication
Old 09-07-2009, 11:40 AM   #1 (permalink)
rickryder is on a distinguished road
Sportster Oil in front pipe
Hello All!
I seem to be getting oil coating my front pipe on my 74 xlch 1000.The motor has 3000 miles on a fresh rebuild....I run with an oil cooler and exposed oil filter up front. On the hottest days the bike runs 150-160 max temp.I am running Kendal sae50... any thoughts? Thanks Ryder
rickryder is offline   Reply With Quote
Old 09-19-2009, 07:01 PM   #2 (permalink)
I am surprised that no one has any thoughts on why oil is in my exhaust pipe
Old 09-19-2009, 09:19 PM   #3 (permalink)
PHUCKING BIKER!
tequacha is an unknown quantity at this point
is it an oily ring on end of pipe? valve guide probably. Totally oiled pipe. rings
Trailering your motorcycle, is a disease. For help dial 1 800 scared to ride
tequacha is offline   Reply With Quote
Old 09-21-2009, 05:45 PM   #4 (permalink)
Site Sponsor
rosascycle's Avatar
rosascycle is on a distinguished road
You should NOT have any oil in the pipes and just after a fresh rebuild start taking it apart. Or take it back to the shop that rebuilt it also is it burning,using, oil ? more that a quart in 700 miles or less That would confirm a problem with that front cylinder or head Iron head XL's are known to leak some oil but not in the exhaust pipes good luck with it
PH: 631-424-4955
Huntington, New York 11743
http://www.rosascycle.com
rosascycle is offline   Reply With Quote
Old 09-21-2009, 07:03 PM   #5 (permalink)
Y2K
Y2K is on a distinguished road
I'd suspect a valve guide was set up too loose or is worn.
Iron XLs have no valve seals so the valve guide to valve stem clearance is critical.
Were the heads redone with the rebuild? big mistake if not.
Y2K is offline   Reply With Quote
Old 09-22-2009, 07:57 PM   #6 (permalink)
Thanks all for your views... It dosent burn oil no smoke from the pipe.... It will use some oil but nothing like a quart in 700 miles...The oil is coating the pipe not just a ring at end... It's not like it's gushing out just a film coat in the pipe....The heads have new guides and valves.... I suspect it's a guide thanks for you input
Old 09-25-2009, 06:50 AM   #7 (permalink)
Iron Will
Hillside's Avatar
Either the guide fitment in the cylinder head, or the guide/valve clearence.
It could also be migrating over the firelip from the oil drain.
Dissassembly and inspection will tell all.
Scott
