Motorcycle-CommunicationDiamond Bar ChoppersMotorcycle.com Classifieds!Bub EnterprisesProCharger.comPro PadSportbikeTrackGearAmerican Side Road CycleMBO Enterprises
Old 08-12-2009, 05:27 PM   #1 (permalink)
diovol is on a distinguished road
shovelhead guru's
so I am in a bind, i took this shovelhead apart because it had a loose valve guide and because the top end was clattering bad. I caleaned out all of the oil passageways in everything and checked all of the tolerences. Everything checked out ok. i put a new relief spring in the pump. I had a machine shop put in the new valve guide and size it for me. So today i put the motor together and fire it and the frigger clatters more than before. now it has a hydraulic to solid conversion kit ( so the lifter, the spring then the solid insert) and adjustable pushrods. I have no freakin idea what to do. The lifters seem fine and if anything the pushrods are on the tight side and still it is clattering soo bad. So any advice would be much appreciated.
is it possible that too tight would cause clattering aswell as too loose?
thanks
diovol is offline   Reply With Quote
Old 08-12-2009, 06:29 PM   #2 (permalink)
first thing first, ya got oil flow from the pump?
Old 08-12-2009, 06:35 PM   #3 (permalink)
Dave63's Avatar
Has anyone had any luck with the hydraulic to solid conversions?
If you run the rods to zero lash, you shouldn;t get noise from them, or so I wouldn't imagine.
Does it run good, but make noise?
Can you feel anything in the pushrod tubes?
Where is the noise emitting from?
Dave
Old 08-12-2009, 07:06 PM   #4 (permalink)
its funny cause i have oil coming fro the lifters and oil going to the oil tube up to the head but i cant see any flow inside the tank, and the noise is coming from the valve train.....
Old 08-14-2009, 11:28 PM   #5 (permalink)
nmaineron is on a distinguished road
I didn't like those conversion setups.They were never quiet and never stayed adjusted for any length of time.I would check to see if one of the inserts isn't binding on you.If it were my machine I would put the hydraulics back in.
nmaineron is offline   Reply With Quote
Old 08-15-2009, 06:03 PM   #6 (permalink)
geoff1200 is on a distinguished road
Check the lifter rollers....
geoff1200 is offline   Reply With Quote
Old 08-18-2009, 04:39 PM   #7 (permalink)
Iron Will
Hillside's Avatar
You need to block off the oil passage in the lifter block.
Also the pushrods need to be adjusted so there is a "drag" on the pushrod itself when trying to turn them.
Scott
Old 08-29-2009, 08:08 AM   #8 (permalink)
Site Sponsor
rosascycle's Avatar
rosascycle is on a distinguished road
Top end noise can fool the best mechanics noise from pistons, push rods, or conn rods, can all seem like top end noise .Did you measure the piston to cylinder clearance? or look at the skirts of the pistons for damage.Any up and down movement in the conn rods? Solid lifters work just fine when adjusted correctly we use the kits with the adjustment in the push rod NOT!! the adjustment in the tappet
PH: 631-424-4955
Huntington, New York 11743
http://www.rosascycle.com
rosascycle is offline   Reply With Quote
