From Dennis Kirk
Now featuring Mikronite surface enhancement on all cams
Strengthens cams, makes them significantly more durable and boosts power by reducing friction losses
Cam surfaces now highly resistant to corrosion
Hydraulic Bolt-In
Broad power range for streetable performance
Works well with stock compression or increased up to 10:1
Low and mid range improvement
Does not require valve spring change
Will increase torque for heavy bikes with heavy loads
Stock carb and exhaust or performance parts may be used
Intake
Duration @ .053 in.: 244 degree
Open: 22 degree
Close: 42 degree
Valve Lift: .450 in.
Exhaust:
Open: 42 degree
Close: 22 degree
(It's made by Crane for a 1970-1977)
