Old 06-14-2009, 07:01 PM   #1 (permalink)
BOWB4ME is on a distinguished road
powder coat ?
gonna have some parts powder coated. was curious about a few things. will the bearing races on the frame, swing arm, and wheel hubs withstand the current and temp of the coating process? or will i need to remove them, which isn't a big deal if need be. but was curious. any other advice about the process? this will be the first time i had anything powder coated so any suggestions will be greatly appreciated.
oh BTW it's a shovelhead frame and parts.
75' shovelhead project
BOWB4ME is offline   Reply With Quote
Old 06-15-2009, 07:21 PM   #2 (permalink)
atrick is on a distinguished road
The current is real low, temp is 400 degrees + or - . Most companies will advise if you should or shouldn't remove
07 FXDWG
D & D Slipons
Redshift 575 cam
SE adjustable pushrods
K & N air cleaner
T-Max w/auto tune
Race Tech progressive wound fork springs & emulators
78 SuperGlide
Andrews B Grind w/solids
S & S Super
Dual Pipes
atrick is offline   Reply With Quote
Old 06-15-2009, 07:56 PM   #3 (permalink)
remove and plug the holes, you will have blast medium and powdercoat in every crevice. also, clean all grease and oil fron the areas to ease cleanup! taping just aint enough. oh, screw disposable bolts in all the holes to protect threads also!
Old 06-16-2009, 08:28 PM   #4 (permalink)
thanks guys.
