You`ve got to get a service manual…
Right side case is held on by corrosion, gasket sealer…
Lay the cases left side down on the bench and tap the right case with a mallet to free it up.
To remove the crank from the left side case, put it in an arbor or hydraulic press, flywheels facing down.
Support the case with wooden blocks. Put some cardboard or something soft under the crank to protect it when it falls out of the case.
Pressing on the end of the crank will push the shaft out of the Timken bearing in the case and the crank will fall out.
The shop manual will show you what pullers you need to remove the other Timken bearing from the shaft.
