Motorcycle-CommunicationLeslie Kay'sAdvanstarMotorcycleShowsAmerican Side Road CycleJekillandHyde.euBikeBanditFuel MotoBub Enterprises
Pro Pad
Dan Vance Racing
Old 05-28-2009, 11:28 AM   #1 (permalink)
Tom Witfield is on a distinguished road
Flywheel balancing
Talked to a guy who said he static balances Harley flywheels that are put togather,trued up and all.Does it on centers like a trueing stand. I've balanced flywheels with an S&S kit. I've seen where they are dynamicly spun and balanced.Do you have any idea how he does this staticly? Nearest thing I've heard of was to have one piston on with 5 pennies in the piston and you balance it like a wheel. Any one have any info on this?
Tom Witfield is offline   Reply With Quote
Old 05-28-2009, 12:03 PM   #2 (permalink)
xtractor's Avatar
xtractor is on a distinguished road
Yes Revolution Performance site sponsers has a four part Pod Cast regarding this, for the tc96.
xtractor is offline   Reply With Quote
Old 05-28-2009, 02:36 PM   #3 (permalink)
Rey
Rey
Let me add a little more confusion to the issue. Static assembled balancing discussed here.
http://virtualindian.org/1techflywheel5.htm
Rey is offline   Reply With Quote
Old 06-01-2009, 02:22 PM   #4 (permalink)
Iron Will
Hillside's Avatar
S&S's flywheel rebuild/balancing tooling, and instructional bulletins,
make no mention of using loose change to aid in the balancing of flywheels.
They have a bob weight system, and formula to establish the dedicated 60% balance factor, when performing that operation, during the flywheel re-building process.
Static balancing is very accurate, done correctly.
Scott
