Sweat it or don't?
Changed oil and filter on the '83 last weekend. Upon startup the oil pressure light acted normally (flickered then went out). When I peeked inside the oil bag I saw no signs of life. Could the stock oil pump be moving oil so slow I can't see it, no air bubbles - nothing?
So far I've only ran the engine less than 30 seconds at a time for fear of damage. Oil filter is in the stock vertical location and was filled about two thirds before installing. All new rubber oil lines and separated the primary last year. The couple of sheared oil pump keys I've seen lit up the warning light.
