Original Linkert Leaking Bad.... HELP!!!
Hope someone can shed some light on this....
The "M" Linkert Carb on my '53 FL WAS fine during last ride (couple weeks ago).... Today I turned the fuel ON to fire it up and gas started POURING our of a small hole under the High Speed Jet adjustment.
I thought the float might be stuck, after tapping with a screwdriver handle (no change).... so, I took the carb off,...
I have since:
Removed and reinstalled the carb 3 times, Checking the Float, the Needle Valve, Float Height (changed this higher and lower),... I have blown compressed air through it thinking maybe some crap was causing the needle valve to hang open,... NOTHING seems to make a difference.
The float is brass and is not leaking....
Any suggestions would be GREAT.
Thanks!
RZ
