Motorcycle.comProCharger.comCustom DynamicsDan Vance RacingCycleGear.comBikeBandit
SportbikeTrackGear
Pro Pad
Old 03-13-2009, 09:07 AM   #1 (permalink)
my383rdrnr is on a distinguished road
need a little help plz 76' ironhead
A friend of mine found a 76 sporty for way cheep but it needed some bolt holes welded on the primary drive just the cover holes. Anyhow the person he got this from had already dis assembled the engine from the bike and had the primary drive disassembled from the engine. My question is this how do you compress the 2 spinngs that go inside the clutch to get the outer plate on. Any tips that do not require a specialty tool would be very apreciated.
my383rdrnr is offline   Reply With Quote
Old 03-13-2009, 09:34 AM   #2 (permalink)
Onerigidrider's Avatar
Onerigidrider is on a distinguished road
You will need a special tool...but you can make it. Also, good reference is ironheadcycle.com
Tool is threaded rods into flat stock that screw into primary cover mounting points to compress clutch basket.
1970 Ironhead Chopper
CTFS QCB
Onerigidrider is offline   Reply With Quote
Old 03-13-2009, 10:08 AM   #3 (permalink)
Perfect solution
Thank you very much!!!!!
Old 03-13-2009, 10:12 AM   #4 (permalink)
strokerjlk's Avatar
It can be done without a specitily tool but is a PITA!
I will admit I was a lot younger braver and stronger then LOL
It takes three determined guys.
One to brace the bike one to push the plate and one to install the nut.
You have to be fast and a little crazy!
After two or three time of doing this I made a compressor much like the one in oneridgidriders post. This has brought back a found memory....as one of the buddies that helped and I later sold the sporty to has passed on.
Good Luck if this is not a matter of necessity as far as time to get it back together I would recommend making the compressor!
07 ULTRA
S&S 106 CI
Big Boyz heads
D&D Fatcat
Hillside/Green A/C
SE 204
GARMIN 2610
3 GAL. AUX FUEL CELL
IBA# 31913
BBG
1566 MI 23 HR'S
Thomas Jefferson
Old 03-13-2009, 07:39 PM   #5 (permalink)
What Starter Button?
77Ironhead's Avatar
77Ironhead is on a distinguished road
I've done with a big jaw puller many times
BUT, it's not worth it as it a dangerous method - make or buy the tool.
77Ironhead is offline   Reply With Quote
Old 03-13-2009, 08:16 PM   #6 (permalink)
wanna ride's Avatar
wanna ride is on a distinguished road
That picture just brought me back 20 yrs
2002 FXDWG
1989 FLHTP
Lynn
wanna ride is offline   Reply With Quote
Old 03-13-2009, 09:09 PM   #7 (permalink)
77Ironhead's Avatar
Yahoo! It's all still good.
Old 05-06-2009, 01:37 AM   #8 (permalink)
guymack's Avatar
guymack is on a distinguished road
I have already take a vice grips and clipped it on the stand-off by the shifter shaft. Got a big breaker bar and held it in place with my knee and compressed the springs. Kinda a tricky one, but worked. By the way I am not shadetree all of the time. Helps to know in a pinch....
guymack is offline   Reply With Quote
