Dying battery...
What could cause my battery to keep dying when everything is turned off. Kind of drawing a blank. No horn, signals, speedo, etc.. Just electric start hooked to toggle on/off with two buttons for start and kill. I just kick it to start though. Key has ign and light turn on points. In order to start the bike I need to turn key to ign and hit the on position on the toggle. Bike has Malory electric ign.
Please note I did not build this bike so I dont know the wiring from top to bottom just yet.
Any tips would be great...
1973 FX frame chopped in the rear with rigid welded in place. Bottom end is 58 panhead topped with 66 shovelhead. S&S super E carb, Andrew B grind cam. 73 4spd trans. Kick and Electric start... A bobber fo sho
