I did it the hard way. Right side off, cams out, pinion drive sprocket off, turn it one notch clockwise, cams in, cover on, turn engine and so on, and so on.
There are seven different possibilities, the first three times piston hit valve on the rear cylinder, the next three times it hit the valve on the front cylinder, and then the seventh time it cleared on both.
Now I have to adjust valves, does anybody know how much?
I have also remounted the clutch, its the type with 6 nuts how tight shall I tighten them?
