Originally Posted by DD Slider
lightly bottom it out then back it out 2 turns then fine adjust...careful when you bottom it out, not to crack the carb housing...
K thanks. Wow, It was at least eight or so turns out on mine. Bike runs much better now, still needs a little tweaking. The choke acutally works right now too, before it would idle way too high when pulled out the slightest bit.
Tightening the screw makes it run more lean and backing it out is to richen it, correct?
