Pro PadLeslie Kay'sRRcycles.com
MBO EnterprisesMotorcycle.com Classifieds!Motorcycle.com
Leslie Kay's
Old 12-15-2008, 04:06 PM   #1 (permalink)
GIBSON is on a distinguished road
Grade 5 or Grade 8 for Rocker Covers?
S&S sends you 16 plain grade 8 bolts for your rocker covers to attach to their super stock shovel heads (5/16-18 x 2 1/2) and 2 Grade 5 bolts (5/16-18 x 1 1/2).
They are plain steel and discolored in less than 1000 miles. Anyways, since my HD rocker covers are now chromed, I picked up 18 beautiful replacements from Diamond Engineering. Come to find out, the whole load is Grade 5 hardness.
Do you think these will do the job for me without breaking apart?
Alternator Shovelhead
93" S&S Sidewinder Kit
GIBSON is offline   Reply With Quote
Old 12-15-2008, 04:17 PM   #2 (permalink)
I like children - fried.
plongson's Avatar
plongson is on a distinguished road
5/16" grade 5 is good for 120,000 psi and about 20lbs torque to start. 5/16 grade 8 is 150,000lbs and about 30lbs torque to start. Torque depends greatly on how clean the threads are and lubrication.
What does the HD manual call for torque on these fasteners? If its just the top cover and not the heads themselves, G5 is probably just fine.
2005 Road King Classic FLHRCI 88"
HQ-34's
HQ Pro-Tune
S&S Geardrive
Baisley LMR-2 15% pressure spring
Arlen Ness Big Sucker
Python pipes
And YES, I have the SERVICE & PARTS MANUAL
plongson is offline   Reply With Quote
Old 12-15-2008, 07:00 PM   #3 (permalink)
grade 5 will work great. torque is in inch pounds.
Old 12-15-2008, 07:14 PM   #4 (permalink)
Need For Speed
motrhd's Avatar
motrhd is on a distinguished road
Yup
"If you don't like the way I'm livin.....then just leave this long haired country boy alone ! "_________Charlie Daniels
motrhd is offline   Reply With Quote
Old 12-15-2008, 08:49 PM   #5 (permalink)
plongson's Avatar
Actually the torque is in Foot/Pounds for this grade of 5/16" screws. A 1/4"-20 socket head, for instance, runs between 90 to 120 INCH pounds.
NONE THE LESS...ALWAYS USE CAUTION AND DESCRESION WHEN TIGHTING ALL YOUR FASTENERS!
http://www.raskcycle.com/techtip/webdoc14.html
HQ-34's
HQ Pro-Tune
S&S Geardrive
Python pipes
Old 12-16-2008, 06:50 AM   #6 (permalink)
Service manual 1970-'77 says 15 FT LBS.
Thanks for yer helps and...
MERRY CHRISTMAS!!!!!
Old 12-16-2008, 08:35 AM   #7 (permalink)
plongson's Avatar
One thing you always have to consider when thinking about "How Tight" is..."What is it screwing into". A G8 screw going into a G8 nut is designed to take the prescribed amount of torque from the tables.
On the other hand, a G8 screw going into a soft metal (aluminum) will pull out the threads long before it stresses the fastener. Many of the HD torque specs assume G5 socket head or Torx head going in soft aluminum are low to protect the female threads.
HQ-34's
HQ Pro-Tune
S&S Geardrive
Python pipes
Old 12-16-2008, 10:25 AM   #8 (permalink)
Finally; I forgot to mention that the bolts I purchased from Diamond Engineering are stainlees steel polished (grade 5). Some say that the stainless steel bolts are the weakest.
What say you???
Furthermore I notice that torque values change when using dry or wet. Should lock-tite be used at all???
Old 12-16-2008, 04:27 PM   #9 (permalink)
What Starter Button?
77Ironhead's Avatar
77Ironhead is on a distinguished road
I don't think the OE studs @ 15 Lbs. is the same as a 5/16 Bolt supplied by S&S. As I recall the OE studs were 5/16 threads and the un-threaded portion looked more like a 1/4 - they were designed to stretch as the rocker box expanded so as to not over compress the fiber gasket . With newer type gasket materials and a 5/16 bolt I would use the spec supplied by S&S.
77Ironhead is offline   Reply With Quote
Old 12-16-2008, 05:14 PM   #10 (permalink)
Well, in my opinion, be careful with stainless and aluminum. The aluminum looses every time. Not that you can't do it, just be careful. Use plenty of Neverseize or Locktite. Stainless bolts are generally a little under grade 5 or so, if I recall. Still plenty strong for holding a rocker box on an aluminum head.
15 foot pounds = 180 inch pounds.
Dr.Hess
http://www.drhess.net
"71"
Old 12-16-2008, 07:12 PM   #11 (permalink)
plongson's Avatar
One thing that I have learned over the years from my 40 or so years the maintenance industry, is that you have to be careful or at least cognizant, that T304 and T316 stainless will actually work harden in high stress applications. Work Harden=stress cracks=failure. Just be aware...
For instance, I would never use say 1/2" SS bolts for a trailer hitch. Pay the man and go G8. These are extreme cases and SS screws are just fine for what they are designed for.
HQ-34's
HQ Pro-Tune
S&S Geardrive
Python pipes
Old 12-17-2008, 12:22 PM   #12 (permalink)
1711tab is on a distinguished road
Grade 5 is more than enough for this application... Your compressing a gasket so it doesn't leak...
1711tab is offline   Reply With Quote
Old 12-29-2008, 10:11 AM   #13 (permalink)
ruben123 is on a distinguished road
Great summation, i always use grade eight..but you do have to be on it when you screw into aluminum..
Good summation..
thanks
ruben123 is offline   Reply With Quote
Old 01-25-2009, 12:10 AM   #14 (permalink)
DD Slider's Avatar
DD Slider is on a distinguished road
I heard loctite is not to be used in Aluminum...?
DD Slider is offline   Reply With Quote
Old 01-25-2009, 02:33 AM   #15 (permalink)
mooooving out!
route66paul's Avatar
don't think about using stainless into the head or any hot spots in thr aluminum. Even with never seize, it can still gall. There is a particuliar chemical reaction here. if you do, use a lot of never seize or a high temp thread compound
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
