Motorcycle.comCycleGear.comCustom DynamicsJardineProducts.comAmerican Side Road CycleSportbikeTrackGearFuel MotoAdvanstarMotorcycleShowsBikeBandit
JardineProducts.com
Old 11-24-2008, 07:11 AM   #1 (permalink)
GIBSON is on a distinguished road
Andrews B for Hydraulic Lifters
Greetings again!
I've decided to use an Andrews B grind in my new 93" shovel. It is my info that this cam is for solid lifters only.
Well, I don't have solids, I now run JIMS tappet blocks, power glide tappets and matching aluminum rods.
Jim Leinweber's website says you can use any of his cams with hydraulics as long as they are JIMS hydraulics or Velva touch.
So, since Leinweber cams are pretty wild, is it wrong to think that I could use this fairly straight ahead B grind successfully?
Heads are duo-plugged & ported S&S
Super E with ThunderJet
S&S Big Bore jugs and forged pistons 9.5:1
CycleRama 5 angle valve job
Cam lift up to .600
JIMS valve train and oil pump
Truett & Osborn Torque Monster 4.5" flywheels
Am I 'under' cammed for this engine. I'd like more torque off the line than upper end hp.
Alternator Shovelhead
93" S&S Sidewinder Kit
GIBSON is offline   Reply With Quote
Old 11-24-2008, 10:15 AM   #2 (permalink)
Site Sponsor
rosascycle's Avatar
rosascycle is on a distinguished road
Yes you can use Andrew's B cam 485 lift with that type lifter you would have a problem with stock H-D hydraulics they are only good for about 450 lift. The stronger lifters cam in production after that cam was introduced.
PH: 631-424-4955
Huntington, New York 11743
http://www.rosascycle.com
rosascycle is offline   Reply With Quote
Old 11-27-2008, 11:29 AM   #3 (permalink)
mrbuzzz is on a distinguished road
Arrow Andrews BH is the answer
I have built many 90-93-96 inch pans with Jims lifters. The best cam for your 93" shovel would be the Andrews BH. The lead in ramps are much more friendlier to hydraulics the the B. If you want more bottom end torque you should dergree the camshaft by 5-8 degrees advanced. I use that cam and degree setting on my 93" Pan that Ipull a camper trailer with. Doesnt reall affect your midrange pull either. I do most of my work on that bike in the 2500-3400 rpm range and can do whatever I want to. If you need that service done to your cam or want a good price on the cam itself please contact me azengineering@bresnan.net
good luck, Buzzz 719-269-2474
mrbuzzz is offline   Reply With Quote
Old 11-30-2008, 10:37 AM   #4 (permalink)
ain't no Geezer Glide
NitroBerserker's Avatar
NitroBerserker is on a distinguished road
Originally Posted by mrbuzzz View Post
If you want more bottom end torque you should dergree the camshaft by 5-8 degrees advanced. I use that cam and degree setting on my 93" Pan Doesnt reall affect your midrange pull either. If you need that service done to your cam or want a good price on the cam itself please contact me azengineering@bresnan.net
How do you do that on that cam? can you just put it in 1 tooth advanced? ( what advance would that be? ) or do you press the gear off, advance it 5 deg. and press it back on?
If Some is Good, More is Better and TOO Much is Just Right.
NitroBerserker is offline   Reply With Quote
Old 12-29-2008, 10:16 AM   #5 (permalink)
ruben123 is on a distinguished road
Dam, that man knows his cams..we just machine the lifter blocks to accept hydralic lifters, high performance and the puupy runs tuff.
ruben123 is offline   Reply With Quote
Old 01-25-2009, 12:02 AM   #6 (permalink)
DD Slider's Avatar
DD Slider is on a distinguished road
I've got an 83 stock bore and stroke, crane fireball cam w/solids, I have wiseco 9.5-1 forged pistons, S&S E w/thunderjet, I'd like to cam it up a notch, I was told the Woods w6s w/510 lift would be awesome, I am wondering if that is the right move? or would the andrews B work better for me...?I do like hammering it now and then...and love that lope...83FXWG
DD Slider is offline   Reply With Quote
Old 05-06-2009, 02:04 AM   #7 (permalink)
guymack's Avatar
guymack is on a distinguished road
I run the BH too. Great power with the super G carb too....
guymack is offline   Reply With Quote
Old 07-19-2009, 12:50 PM   #8 (permalink)
PanHDSam is on a distinguished road
I run BH and Super E in 80" Pan.
64 FL
70 FLH
08 FLSTSB
05 FLHTC 113" Carbureted Build / 6 speed add / lots of other stuff.
PanHDSam is offline   Reply With Quote
