Normal oil temp 93" S&S stroker?
My bro is running the 93" sidewinder kit. Runnin down the highway the oil is at 220deg on a 68 degree day. This seems awful hot and he thinks it was losing power on the 20 minute highway blast. I know there are a ton of variables, just need to know the normal oil temp range.
95" new dyno sheet soon 11:1cr Triple XXX S&S carb w/Green filter
Axtell Prostreet Pistons
SE roller rockers & rocker support
Fueling cam plate, oil pump, & 'B' lifters w/limiters
Leineweber T7 .603" gear drive cams
Larry Long portwork
TwinTec ignition
Baker Clutch
Vance&Hines Outlaw 2into1
3.37's
Pirelli tires
Amsoil
