fork oil level??? dyna 2000i
Hi, I'm new here and have been reading through the old threads and have learned a lot. I have a 77'fx 74" changed over the years,I've owned it 2yrs, been piecing this shovel into a fine ride the last couple years and have done a bit of head scratching at times, but been happy with it!!! Long winded,sorry....I have an 80 something WG 41mm front end with 33" legs,I'm putting on new one's I picked up, 34"...Is the oil capacity the same as stock(clymer's)???? If not anyone know where I can find the level????.
Also I just installed a dyna 2000i. First I timed it with the l.e.d. at the 35dg mark...ooops,started hard, ran good under load but bucked at steady throttle at all rpm, re-timed it at TDC(the dot,not the line!!! ) and it would pop bad out the carb, so then I went back to the old EAR and it seems to pretty good now, right in the middle of the 2 spots previously. Can that be normal????
Any help greatly appreciated, Thanks Stu
