SportbikeTrackGearLeslie Kay'sCustom DynamicsFuel MotoDiamond Bar ChoppersAmerican Side Road Cycle
Motorcycle.comMBO Enterprises
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > V-Twin Performance Forums > Pre-Evolution Engine Mods
Pro Pad
Old 11-02-2009, 09:43 AM   #1 (permalink)
mark982 is on a distinguished road
su carb belching gas
go a 67 shovel, i run a su carb on it. love the carb,very simple but i can't get it to quit puking gas on my right pant leg. i changed to the cam that rivera said would elimate that,but it didn't,went to a smaller jet same thing. anything else i could do.
mark982 is offline   Reply With Quote
Old 11-02-2009, 10:07 AM   #2 (permalink)
is it flooding at idle? do you have straight pipes?
Old 11-02-2009, 04:56 PM   #3 (permalink)
no,it's not flooding at idle, i do run straight pipes. 1-3/4x 38". cant figure this out. bike runs great otherwise. what's also strange is i have to run 2 different heat range plugs colder in the rear. i thought compression might be the problem,checks within 5 pounds of each other.
Old 11-02-2009, 07:17 PM   #4 (permalink)
install mufflers. some old shorties will do the trick.
Old 11-02-2009, 09:24 PM   #5 (permalink)
explain the shorty pipes, don't understand that one. at this point i'll try anything.
Old 11-03-2009, 09:59 AM   #6 (permalink)
slip ons, they are about 6-8 inches in length. still available from paugco i believe. of course you can find any slip ons, they will all help your problem.
Old 11-03-2009, 04:01 PM   #7 (permalink)
Axe Man
BVBOB's Avatar
Love the look of that SU carb setup, what is likely causing your problems and what I am guessing that Claydbal is getting at is you are experiencing reversion, the mufflers will help but you might also try the old trick of a couple of bolts crossways in the end of the pipes to break up the exhaust wave if you like the sound now.
2007 Ultra
Woods 7H cams
Heads ported by BigBoyz
D&D Fatcat, SE/AC
1982 FXRS
Scratched paint
Rotten tires
Bad brakes
Sticky clutch
Still runs like a champ!!
Old 11-03-2009, 10:18 PM   #8 (permalink)
bvbob,thanks now that's something i can understand. i really do love the su(it's like me --simple)
Old 11-04-2009, 10:30 AM   #9 (permalink)
stroker93 is on a distinguished road
what size of jetting??? what size of motor??? I've SU carbs bout 10 yrs now..I don't have any issues like that and run drag pipes,,2 into 1 homemade set ups,,and now run"thrush" glass papacks for mufflers...What air cleaner????Some cleaners with let the fuel "draft" outta carb when goin down highway,,actually suck out gas onto leg..I would guess jetted to big..these carbs are a constant velocity they pull in fuel from motor vacuum,,,check jets and get back to use with sizes..
dave
stroker93 is offline   Reply With Quote
Old 11-04-2009, 01:07 PM   #10 (permalink)
Iron Will
Hillside's Avatar
You can control the reversion via using a 1/4" bolt, 1 1/2" long, installed 3" from the end of the pipe, and stack as many 5/16", or 3/8" nuts on it as you can.
Still have the sound/look of the open pipe, and the low end torque will come up, and your carb issue should end as well.
Scott
