I would use a "dial back" timing light as mentioned below but remember for dual plugs run total advance at 28-30 degrees.
USING DIAL BACK TIMING LIGHT
Determine the advance you want at 2,500 RPM. Use a dial-back timing light. Set the amount of advance you want, say 35 degrees, on the dial-back timing light. Connect the dial-back timing light to the front cylinder. If the VOES is used, disconnect the VOES input (purple/white wire) while setting the timing with this procedure. Set the ignition module advance slope switch for maximum advance. Run the engine at 2,500 RPM. Rotate camshaft position sensor until TDC timing mark is centered in the observation hole. You will now have the amount of advance you dialed into the timing light. Tighten the standoffs and verify that timing has not shifted. Some dial-back timing lights are not compatible with odd firing H-D ® V twin engines. Most Sears units are OK. Snap-On units may not function correctly.
1982 SHOVEL - 96"
2002 FLHT STD
95" - 9.8:1 Comp
Wiseco Flattop Pistons w/ thermal barrier coating
Dewey's Pro Street Heads
Andrews 37G
Mikuni 42 Carb
Zippers adj. Ignition
LSR 2-1
