JardineProducts.comBub EnterprisesLeslie Kay'sCustom DynamicsMotorcycle-CommunicationMotorcycle.comSportbikeTrackGearBikeBanditProCharger.com
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > V-Twin Performance Forums > Pre-Evolution Engine Mods
Old 06-20-2009, 02:48 PM   #1 (permalink)
Livin' the life
Mother's Avatar
Mother is on a distinguished road
options for 4spd shovel...
Working on a '81 flh with a 93" stroker. Currently has 4spd with Andrews gears. Would really like to go to a 5 spd. What are the options? Stock 5spd? Baker? Revtech? Andrews?
95" new dyno sheet soon 11:1cr Triple XXX S&S carb w/Green filter
Axtell Prostreet Pistons
SE roller rockers & rocker support
Fueling cam plate, oil pump, & 'B' lifters w/limiters
Leineweber T7 .603" gear drive cams
Larry Long portwork
TwinTec ignition
Baker Clutch
Vance&Hines Outlaw 2into1
3.37's
Pirelli tires
Amsoil
Mother is offline   Reply With Quote
Old 06-20-2009, 08:54 PM   #2 (permalink)
Iron Will
Hillside's Avatar
I believe that you can get a 5 into 4 conversion kit.
Scott
Old 06-21-2009, 06:31 AM   #3 (permalink)
Livin' the life
Mother's Avatar
what kind of money are we talkin'? All I can find is the 6 into 4 and thats too many beans for my brother to spend.
Larry Long portwork
TwinTec ignition
Baker Clutch
3.37's
Pirelli tires
Amsoil
Old 06-21-2009, 09:27 AM   #4 (permalink)
springer-'s Avatar
There are many 5 in a 4 conversions available. Sputhe, revtech, Baker and several others offer them I believe. I used the Sputhe and have no regrets. Personally I would not use any of the cheaper kits like the revtech. Depending on you skill level it can be a costly upgrade since none of them are "bolt in" kits. They all require some level of modification to install. If I had to guess I would say expect it to cost over $2000 by the time you are done.
207-621-8089
Old 06-21-2009, 01:42 PM   #5 (permalink)
Iron Will
Hillside's Avatar
Have used a ton of Baker products.
They'd be your best bet.
Scott
Old 07-22-2009, 11:30 AM   #6 (permalink)
v10ole is on a distinguished road
Thumbs up
Rivera Primo makes a nice set up 6 speed 3 inch open belt primary I got one and let me tell you its great get the whole package with a starter that works, 75 MPH and the tac reads 2900 RPM
v10ole is offline   Reply With Quote
Old 07-23-2009, 02:59 PM   #7 (permalink)
PHUCKING BIKER!
tequacha is an unknown quantity at this point
24tooth on counter shaft 47tooth on the rear
Trailering your motorcycle, is a disease. For help dial 1 800 scared to ride
tequacha is offline   Reply With Quote
Old 07-24-2009, 04:34 AM   #8 (permalink)
grouch1957 is on a distinguished road
like tequacha says, regear 24-48, or 47. i have a 90" shovel 3.5 bore x 4.75 stroke, had it geared 24-48. worked well. now have a Baker 6 into 4 w/kicker works even better, but you are talking some bucks. you could also fit softail 5 speed trans. takes some mods tho. need special trans mtg plate, need to grind on trans to clear swing arm and use softail primary and starter. basicly thats what the Rivera Primo kit is doing. going with wide ratio gears in for speed and regearing trans and wheel sprocket cheapest way to go
grouch1957 is offline   Reply With Quote
Old 07-24-2009, 03:42 PM   #9 (permalink)
Livin' the life
Mother's Avatar
thanks, regearing sounds like a good option
Larry Long portwork
TwinTec ignition
Baker Clutch
3.37's
Pirelli tires
Amsoil
