Dan Vance RacingMotorcycle.com
Fuel MotoProCharger.comRRcycles.comMotorcycle.com Classifieds!
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > V-Twin Performance Forums > Pre-Evolution Engine Mods
JekillandHyde.eu
Old 03-16-2009, 07:03 AM   #1 (permalink)
Iron Will
Hillside's Avatar
103" Shovel
My brother pulled the engine to check it over.
5" stroke, 3 5/8 bore.
Lieneweber L-6 cam.
Both ot theses items are known to cause wear, but much to his surprise, the pistons look like they came out of the box, the guides/springs are in great shape, and very little wear in the cylinder bore.
Engine has over 25,000 on it.
What we are attributing this to is proper assembly, proper break-in, and NOT beating the snot out of it all the time.
Scott
Old 03-16-2009, 08:25 AM   #2 (permalink)
FXRS is on a distinguished road
So . . . . .your shop built this?
Any performance numbers?
FXRS is offline   Reply With Quote
Old 03-16-2009, 11:06 AM   #3 (permalink)
Iron Will
Hillside's Avatar
With modified OE castings, an S&S G carb with a T/jet, Dyna ignition, and 1 3/4" drag pipes, with "bolts" in them, it showed just a tick over 100 hp, and 111 and change, on the torque, here on our Dynojet 150.
Bike weighs well under 500 lbs, so that said, it pulls around most others out there, to say the least.
Scott
Old 03-16-2009, 04:18 PM   #4 (permalink)
scott, thats ol skool hot rod! stroker plates, iron oxide coating inside cases,two coils, four plugs----- a protective cup for the nads, oh-my.
yeah, im old.
BTW, am i close?
Old 03-16-2009, 06:22 PM   #5 (permalink)
Iron Will
Hillside's Avatar
yeah, im old.
BTW, am i close?
S&S cases, but he never had me dual-plug it for him.
Dennis, that sucker has quite an exhaust note!!!!!!!!!!!!!
Scott
Old 03-16-2009, 07:11 PM   #6 (permalink)
i bet it does scott. so the thing sounds like it fires on evry tenth revolution while idling at 1400 rpm?
Old 03-16-2009, 11:28 PM   #7 (permalink)
Premium octane member
TXCHOP's Avatar
Music to mine/your ears! Next time i am up at your shop Scott i gotta hear that thing!
Bring that bike by a dealer on a Saturday and just look at all the people that just DONT get it. Then race their screamin chicken 103's for pinks.....
Axtell 117 cyls and pistons
Mikuni HSR48
S+S Super D manifold
Black Boarzilla
TXCHOP is online now   Reply With Quote
Old 03-17-2009, 07:23 AM   #8 (permalink)
Iron Will
Hillside's Avatar
Dan,
That would be totally unfair, at even the 110" level, but fun.
Scott
Old 03-17-2009, 07:48 AM   #9 (permalink)
just like gettin laid. if its fun----its fair!
Old 03-17-2009, 09:28 AM   #10 (permalink)
02 RK,S&S 124" Evo
dog155's Avatar
dog155 is on a distinguished road
Years ago I was talked out of the 103" in my 79 FXEF,settled for a 93"Oh well! Anyway another friend built a 103" Pan,and that was a savage Harley.He was unbeatable,partly because he was so crazy.Man, I miss those days!Thanks for the memories!
06 RK,155" R&R TwinCam
02 RK,124" S&S Evo
dog155 is offline   Reply With Quote
Old 03-17-2009, 09:42 AM   #11 (permalink)
Iron Will
Hillside's Avatar
Has more of a John Deere A, high-idle to it, but very SHARP!!!!!!!!!!!!
Old 03-19-2009, 08:49 AM   #12 (permalink)
02 RK,S&S 124" Evo
dog155's Avatar
Now that is something I relate to big time.My John Deere 60 has an incredible idle with the straight pipe on.Course the big inch Harleys
have more crack at idle,then again the compression is about double over the JD's
02 RK,124" S&S Evo
Old 05-17-2009, 11:38 AM   #13 (permalink)
Livin' the life
Mother's Avatar
Mother is on a distinguished road
Hillside, my brother has a 81 FLH. It has a 93" S&S sidewinder w/S&S cases. he wants to deck the jugs to get 10:1 compression(curreently 8.5:1), RB Racing 2into1, and a Leineweber L51 cam. What would be your opinion on this set up? He already has a modfied S&S 'e' with t-jet and a DTT ignition. By the way he weighs at least 330lbs and its a full dresser. How much lift can he go without machine work to the heads(he currently has the S&S 514 cam)? Is there another cam you like? Your opinion on a pipe?
95" new dyno sheet soon 11:1cr Triple XXX S&S carb w/Green filter
Axtell Prostreet Pistons
SE roller rockers & rocker support
Fueling cam plate, oil pump, & 'B' lifters w/limiters
Leineweber T7 .603" gear drive cams
Larry Long portwork
TwinTec ignition
Baker Clutch
Vance&Hines Outlaw 2into1
3.37's
Pirelli tires
Amsoil
Mother is online now   Reply With Quote
Old 05-18-2009, 07:01 AM   #14 (permalink)
Iron Will
Hillside's Avatar
That 51 is one hellva cam.
Should work very well.
We can deck the cylinders to raise the compression.
Scott
Old 06-02-2009, 07:10 AM   #15 (permalink)
Iron Will
Hillside's Avatar
Andrews has a "group" of high lift shovel cams that work very well in the proper application, but it is MIGHTY tough to beat a Lieneweber in those Shovels/Iron XL's.
Scott
