CycleGear.comMotorcycle-CommunicationDan Vance RacingJekillandHyde.euPro Pad
Motorcycle.com Classifieds!Fuel MotoBikeBanditDiamond Bar Choppers
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > General Discussion Forums > Police Motor Unit General Discussion
Old 10-11-2009, 01:59 PM   #1 (permalink)
wick is on a distinguished road
tour pak wiring ?
i picked up a used tour pak.to put on my 06 flhtpi
the pak has the side lights and no rear lights
there is a wire with a plug inside the pak
im looking for the wire to connect the pak to the bike
the guy at the parts counter wasnt much help
anyone know the pt # for what i need, and where it connects on the bike. im also going to get the h/d led spoiler since the pak has no rear lights how will that fall into the wiring
thanks gary
wick is offline   Reply With Quote
Old 10-12-2009, 10:36 PM   #2 (permalink)
hadaz is on a distinguished road
You should have loom at the back of the bike,comes out from under the seat. It should include the cable for the antenna, a wire with an orange cap on it (which is used for the lamp pole on police bikes) and the other wire with a black connector. That one is normally plugged into the blue running lights at the back of the police bike. If that is there than you can just un connect that light and it should plug in directly to the tour pak.
hadaz is offline   Reply With Quote
Old 10-13-2009, 07:41 PM   #3 (permalink)
thanks found it with the antenna line.
laid the tour pak nxt to bike plugged it in and turned on ignition
and running lights came on, almost ready for mounting,
Old 10-13-2009, 07:50 PM   #4 (permalink)
is the wire with orange cap
powered & operated by the 3 way switch
i would like to get some aux lights on engine guard
and use either switch siren or 3 way
Old 10-13-2009, 11:11 PM   #5 (permalink)
Yes it is, the first position is off, 2nd position would turn on the pole lamp and the 3rd position turns on the pole lamp and the pursuit lights in the front of the bike
Old 10-20-2009, 08:38 PM   #6 (permalink)
would you happen to know where i can find the wires from the siren switch ??
