Cellino&Barnes Motorcycle AttorneysCheapCycleParts.comMotorcycle.com Classifieds!KewlMetal.comSpringfield ArmoryCycleGear.comProCharger.comStoneyStraps.comLawTigersCrystal-GloTech N' Cycle GearRacerPartsWholesale
Go Back   V-Twin Forum : Harley Davidson Motorcycle Forums > General Discussion Forums > Police Motor Unit Forum
Pro Pad
Old 08-03-2008, 11:39 AM   #1 (permalink)
cycopostie is on a distinguished road
Reinstalling tach on '03 FLHPI
I recently got an '03 Police Road King that had the tach removed, I picked up a tach on Ebay that said it was off an '03 Police RK. Funny thing there is the part # on it is 67042-04B.
There is no wiring with the tach but a receptacle that will take a 5 prong plug inside it.
My question is : Is there a short harness with a plug on each end that plugs into the tach and into the wiring harness,or is there a harness that comes from the main and just plugs into the tach.
What wiring do I need to reinstall the tach?? Any tips /help is appreciated.
cycopostie is offline   Reply With Quote
Old 08-03-2008, 12:48 PM   #2 (permalink)
Scary Paranoid Loonie
route66paul's Avatar
I have an 04 and when i removed mine, i just unpluged it, the other peice is still there, behind the headlight.
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
Andrew's 37 cam
Atwood's street ported heads
.030 head gasket
SuperTrapp Supermeg 2in1
Steve Handy dyno map
"43" points cover
Custom after Crash
TRW rear mount
Just sayin..........Dumbasses
Old 08-03-2008, 04:51 PM   #3 (permalink)
Thanks Rt66Paul, the Supp. Man. show's the wiring for it and it looks like a pin connector in the tach(108C) and a socket connetor on the other end(108B).I 'd say the tach I got is the same as yours, esp with an '04 part number on it(can't see it being an '03 tach). I 'm changing the bars for more pullback when the rain lets up,so I'll look for it then. Do the connectors on the bike have the numbers on them(108B-108C)?? Sure would make following the wiring easier.
Old 08-03-2008, 05:56 PM   #4 (permalink)
My wires don't have numbers, but i did not look for them, the looms should. The wires are color coded, you might mistake 1 wire, but if the pair doen't have the right colors, it is not the correct pair.
There are 5 wires, but unless you have the pursuit lightd hooked up you won't nrrd them all
43%er
Andrew's 37 cam
.030 head gasket
"43" points cover
Custom after Crash
TRW rear mount
Old 08-03-2008, 06:45 PM   #5 (permalink)
I meant the plugs and connectors, on the schematic there are 3 connectors labeled 108A,B and C.I just gotta find a 3 wire empty plug with an orange,black and pink wire.Thats why I was thinking there is a short harness between the Main and inside the tach.
Thanks again for the help man, I'm gonna check the sockets to see if they're numbered too. I found a Orange and Black 2 wire socket not pluged into anything coming from under the tank going to the neck and just tucked in with the harnesses. I first thought that was for the tach but won't reach up to the top clamp.If its numbered I'll know what its for without tracing it back.
