10-03-2009, 05:20 PM
S&S carb help
ok got an S&S super g on my sporty. wont start after i wasnt able to ride over the summer. so i dropped the float bowl out and cleaned it up. took the accelerator pump apart and cleaned all that up. put it back together and it still wont start. i took the plugs out and noticed that they are getting wet. i tried ether but it didnt start with that either. you guys know what i should do to get this thing running?
10-05-2009, 05:55 PM
First thing I do is take off the air cleaner cover and check to make sure the accelerator pump is squirting into the carb. If it's not, you know you've got a problem getting fuel...
Are you sure the plugs are fireing?
You can also try aeresol "starting fluid." That gets my dad's shovel started after it's been sitting for a while. Just spray it in the air intake while you crank the starter.
10-05-2009, 07:15 PM
do you have spark ?
02 roadking-lv it
73 xlch
07ducati 1098s
trek 6500
no helmet or training wheels
10-08-2009, 06:36 AM
Originally Posted by ironheadbuck
do you have spark ?
Yea, that sounds like an ignition problem, not a carb. S&S carbs are pretty reliable.
I like the way the lines run down the back of her stockings
10-08-2009, 06:57 AM
0043--Licensed to Doof!
And I think the G is too big for a sporty too.
I Doof, therefore I am.
D.F.F.D
Iron Will
As already mentioned, sounds like a spark issue.
Pull the plugs, and let them lay on the fins and wing it over, while watching them to see if any and spark is occuring.
Scott
10-10-2009, 11:31 PM
+1........
______________________
80" EVO, .020 over, 9.7:1
Keith Black Pistons
Ness Big Sucker
CV w/ DynoJet Kit
Screamin' Eagle Ignition
Screamin' Eagle Heads
V-Thunder 3030 Cam
Sifton Lifters
Crane Adjustable Pushrods
Carlini Torque Arm
Custom Porker Pipes
_______________________
10-12-2009, 07:08 AM
Iron Will
I did not catch it earlier, that it was a G.
The signal is very low when those are on a 1200.
LARGE jets will/may be required to get it going.
Try a 36/80 for starters, and jet from there.
Scott
10-12-2009, 10:50 PM
When the same thing happened to my FXR ( shorty e ), turned out to be a bad ignition module!
