Anyone up for a ride to Shanksville, PA Flight 93?
Checking to see if there is any interest in a run up to Shanksville, PA Flight 93 crash site? It is about 45 minutes past Cumberland, MD. Planning on taking MD 32 to old route 40 to Cumberland and a couple of country roads up through WV and PA from Levale, MD. It is a great ride I've done it a couple of times, round trip is around 400 miles, could also swing by Deep Creek Lake if interested! Would like to do this on the 4th but I know some of you have family and it may not be a good time?
Jerry W. Shepherd
06 FXSTBI 95ci
Dewey Prostreet heads 74cc decked .60
(V-Thunder Behive springs .600 lift 160 lbs,
1.900 intake and 1.570 ex valves,4 angle valve job. 10.5:1 Comp,
Hydrolsolid lifter, DarkHorse Crank
Crane 1-4003 .600 lift gear driven cams,
Mystfree, Wiscoe flat top pistons
Rinehart Stagg Duals
Dakota Kid bored 49.5mm EFI
SE 90 degree Heavy Breather
MFI Stage III 5.7 Gm/s Injectors
SE oil pump & plate, Bandit Sportsman clutch, Timken
THUNDERMAX w/Auto Tune.
