New Guy From North Georgia : V-Twin Forum: Harley Davidson Forums
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > V-Twin Forum > My Story, the Beginning...
Old 11-20-2012, 08:22 AM   #1 (permalink)
standonit is on a distinguished road
I am from a little town called Dahlonega in north geargia. I have had several harleys but I recently purchased a 1984 softail. I love the bike and look forward to keeping it for a long time. I do have an issue with the bike that maybe someone can advise me on. When I try to start it with the key it will at times just click..but if you try it a couple more times it will often turn over and fire up. The battery seems to be fine, the lights are bright and they do not dim when it turns over. Has anyone run across a problem like this? Thanks for any help you can give me....
standonit is offline   Reply With Quote
Old 11-20-2012, 10:10 AM   #2 (permalink)
webco2 is on a distinguished road
welcome to the forum
webco2 is offline   Reply With Quote
Old 11-20-2012, 11:21 AM   #3 (permalink)
thefour's Avatar
thefour is on a distinguished road
Welcome from the west side of Georgia.
thefour is offline   Reply With Quote
Old 11-20-2012, 12:26 PM   #4 (permalink)
Barney Fife - Fake Biker
<G Man>'s Avatar
<G Man> will become famous soon enough
Welcome from just across your north border.
Check for a loose cable connection or put the battery on a tester. Batteries are funny things. I thought my last one was ok too, right up until I finally replaced it.
G Man
'97 FLHPI
80c.i. - EV27 cam - stock pistons - stock heads
SE a/c - Rinehart True Duals - Barnett performance clutch
MM EFI - hi flow injectors - PCIII USB
Tru-Trak stabilizer - customized Corbin seats - beach bars
chrome crap - detachable stuff
<G Man> is offline   Reply With Quote
Old 11-20-2012, 06:49 PM   #5 (permalink)
Richard001 is on a distinguished road
Welcome
Welcome to the Forum
I am originally from Dawsonville. Moved to Milledgeville 12 year ago.
This Forum has been a great help to me.
On the click click then start. Have the battery checked and clean every connection first. I would also want to know if it cranks every time with a battery booster connected. This would indicate a bad battery. What is the battery voltage at rest and when cranking. Should be around 13 at rest and not drop to far when cranking. Another thought would be to use a jumper on the starter just to see if you get similar results.
Richard001 is offline   Reply With Quote
