ProCharger.comRRcycles.comMotorcycle.com
Pro PadAdvanstarMotorcycleShowsMotorcycle-CommunicationLeslie Kay'sJardineProducts.comCycleGear.comMBO Enterprises
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > Motorcycle Related Groups and Forums > Motorcycle Rider Safety Tips
Old 04-27-2009, 02:44 AM   #1 (permalink)
Nazzdak's Avatar
Nazzdak is on a distinguished road
My top ten rules of the road.
Hello Everyone-
Another riding season is here. With motorcycle popularity at an all time high, many people, young and old are hitting the road for the very first time in 2009. For the very first time in my life, I am beginning to see a lot of women riding their own motorcycles. All of this is great news.
Unfortunately, every new season also brings with it, a slew of accidents. So I thought it would it be a great time to re-share the top ten things that I have learned over the last 5 years/53,000 accident free miles.
1. A whopping 77% of all motorcycle accidents are the result of rider error. Thus every time you hear about a rider going down, there is a 77% probability that...
a. No other vehicle was involved
b. The rider failed to negotiate a curve, was in an Intersection at the time of the accident, or was less than 5 miles from his home.
c. The rider had NOT read the book "Proficient Motorcycling" By David L Hough.
If a, b, or c applies to YOU, go out and buy this book yesterday and read it from cover to cover. If you should ever tire of reading this post, then by far, this is the very best advice I can ever give.
2. Get into the front brake habit.
The next time you have a chance, I want you to go out to your garage and practice squeezing, not grabbing the front brake, with all four fingers, while counting out loud, "one, one thousand." Do not "jerk" or "grab" the front brake, Squeeze it, while simultaneously counting out loud "one, one thousand." If you have squeezed the front lever to a complete close, before you have counted "one, one thousand" out loud, you are squeezing too much of the lever, too fast.
For a demonstration of this exercise, please feel free to visit this website....www.youtube.com/conedown
By far, this is the single most important motor exercise in the world. You absolutely MUST practice it at the beginnig of EACH riding season. Find an empty parking lot, get your wheel speed up to no more than 20mph, and start working on this exercise asap. In an emergency, you WILL stop, as you have practiced.
If you have not practiced this exercise, then, in an emergency, you will most likely brake as if you were driving a car, with your right foot, instead of your right hand. This, in turn, will lock up the rear wheel long before it brings to the motor to a stop. Faced with this kind of sensation, most people will PANIC, and release the rear brake. At this point, the rear tire of the bike will spin back to center so violently, that it will create what is known as a highside flip off the motor.
I am telling you from experience, sooner or later, you WILL find yourself in a situation that requires motor skill, not luck. In addition, dumb luck ALWAYS runs out.
Remember, Squeeze, with all four fingers, while counting out loud, "one, one thousand." This braking method has saved my life, more than once. I am not kidding.
3. Inflate your tires up to the MAXIMUM psi. On my 2007 stock FLHRC, that means 40 pounds in the front, and 40 pounds in the back. Check your tire pressure religiously. At LEAST once a week.
4. Always remember to look FAR ahead of the motorcycle. 10-12 seconds is the ideal time horizon. In addition, limit your wheel speed, to your site distance. Obviously, if you can see 10-12 seconds ahead, you can throttle pretty hard. Conversely, if it is, say , foggy, and you can only see 4 seconds ahead, cut your wheel speed down to no more than 40mph.
5. Countersteer, countersteer, countersteer.
I could go on and on about this for hours. If you don't know how to do this, start with the book. It goes into the basics of countersteering in great detail.
6. When you are making a turn through an intersection or curve, remember to also TURN your HEAD! Sounds silly, I know. Just try it. Believe me, it will make a HUGE difference.
7. When you approach an on ramp, or off ramp, think outside the curve, then inside the curve, then outside the curve. If you don't know what I am talking about, again, please BUY THE BOOK! It is no accident that a third of my top ten is dedicated to countersteering through turns or curves. For it has been my experience that this is the area where the most people show the least amount of motor skill. If you are new to motorcycling, then please know that it is HERE where you will find yourself to be the most vulnerable.
8. When you want to pass, first check your mirror. If something is in your mirror, don't even bother. If nothing is in it, turn on your turn signal. At this point, casually check your blind spot. If nothing is in your blind spot, only then should you begin to pass.
9. Never, ever, put the motor in neutral while you're out in the street. NEVER. You wouldn't put your car in park at a stop light. So why would you put your motorcycle in neutral? If this applies to YOU, please, please, please break this habit, and break it yesterday. By far,it is the worst that I have seen. Obviously, you will see the most people doing this at stop lights. The ironic thing, is that this is the precise moment when you should be the most paranoid, not the least. instead, keep the bike in first gear, one eye in your rearview mirror, your brake light ON, with ten feet of available space in front of you at ALL TIMES.
10. Above all, no matter the situation, don't ever stop riding the motorcycle. It is far better to ride the bike into the ground, than it is to ever stick a foot out to try to prevent it from falling over. It is also better to get as much speed out of the motor as humanly possible, before a potential impact, than it is to ever purposely try to "lay the bike down", or 'eject" yourself. For the motor offers far more protection than you can possibly imagine with your body attached to it, rather than from it.
Good luck, God Bless, and safe motorcycling everyone!
David
Nazzdak is offline   Reply With Quote
Old 04-27-2009, 02:54 AM   #2 (permalink)
AnakinsKid is on a distinguished road
I just bought my first bike 2.5 weeks ago, and will be taking the MSF class in another 2. This is exactly the kind of stuff I'm looking for. I'll be buying that book as soon as I can find one.
AnakinsKid is offline   Reply With Quote
Old 04-27-2009, 02:11 PM   #3 (permalink)
KcCrossbones's Avatar
KcCrossbones is on a distinguished road
Excellent, Excellent advice. I hope everyone gets to read this and takes something away from it.
I appreciate it because there is at least one thing in here that I had forgotten about since I last took my class.
Thanks for putting the time in to put this out there.
"Great spirits have often encountered violent opposition from weak minds." -Albert Einstein
KcCrossbones is offline   Reply With Quote
Old 04-27-2009, 09:32 PM   #4 (permalink)
I'm Your Huckleberry
Mr Cujo's Avatar
Mr Cujo is on a distinguished road
Excellent advise.
Though I'd suggest to never be casual about checking a blind spot.. (#8)
I've had things from cars to Electraglides sneak in there and scare the crap out of me...
The Fair Tax- (go ahead, click it.)--
'07 Ultra -> Covington, Ga.
Mr Cujo is offline   Reply With Quote
Old 04-27-2009, 10:36 PM   #5 (permalink)
rtb
03 Heritage
rtb's Avatar
rtb is on a distinguished road
Nazzdak, thanks for sharing. Good stuff you mention. I can't agree more..."Proficient Motorcycling" is a must read. Be safe folks.
26G cams
SE pro torque mufflers
SE air cleaner
Cycle Electric stator + regulator
rtb is offline   Reply With Quote
Old 04-27-2009, 10:41 PM   #6 (permalink)
hdwoman48's Avatar
hdwoman48 is on a distinguished road
Great post! I reread David Hough's book regularly and have gone to several of his talks. His tips are invaluable, especially for new riders.
Annie
2008 FLSTC Heritage Softail
Rinehart ST Slip-Ons
SE Stage 1 Air Filter
SE Pro Super Tuner
Rich's custom seat
Good girls go to heaven. Bad ones go to hell. And a girl on a Harley goes anywhere she wants.
hdwoman48 is offline   Reply With Quote
Old 04-27-2009, 11:15 PM   #7 (permalink)
FOG
trooper113's Avatar
trooper113 is on a distinguished road
While I can't claim to be a motorcycle "expert", I know of no manufacturer of tires (possible exception of Metzeler), bikes or cars that recommends max sidewall air pressure for normal riding/driving. There are a few circumstances where this practice is appropriate, but it's not the norm. In normal riding/driving, max pressure gives you excess center tread wear, a harsh ride and strange handling and traction. I do agree with checking your air pressure a minimum of once weekly.
trooper113
NRA Endowment Member
AMA Member
trooper113 is offline   Reply With Quote
Old 04-27-2009, 11:44 PM   #8 (permalink)
I haven't seen your bird.
MadCity's Avatar
MadCity is on a distinguished road
I'm leaning in trooper's direction on this one. I follow the manufacturer's recommendation — 30 psi in front, 35-40 in the rear (the latter if carrying a passenger).
03 XL1200 Custom
MadCity is offline   Reply With Quote
Old 04-27-2009, 11:48 PM   #9 (permalink)
FOG
trooper113's Avatar
The book recommendation obviously depends on the bike and loading. My '07 Ultra book says 36/36 with the rear increased depending on load. I normally run 36/38 due to my weight plus normal load.
trooper113
AMA Member
Old 04-27-2009, 11:52 PM   #10 (permalink)
MadCity's Avatar
Yes, of course. I was talking about my Sportster, with only me, or maybe one passenger, on it.
03 XL1200 Custom
Old 04-28-2009, 12:02 AM   #11 (permalink)
FOG
trooper113's Avatar
Yup...I well and fondly remember my Sporty. I wish I could afford two bikes....I's still have it. It was a 2003 1200S...a real screamer.
trooper113
AMA Member
Old 04-28-2009, 04:57 AM   #12 (permalink)
Nazzdak's Avatar
Guys-
Once again, my opinions are based on my experience in the saddle, my instructor, who is probably in the top 1% of Harley Davidson riders in the country, and the recommendations of my mechanic, who is the very best at my dealership, and knows a hell of a lot more about motorcycles, than I do.
I just replaced the rear tire on my 07 FLHRC. It was a stock tire. Nothing special. I put the tire on at the 14,678 mile mark last June. I replaced the tire at the 25,630 mile mark, last Saturday. There was 1/32 of tread left. In between I rode my bike from Indianapolis In, to Wichita Ks, went through a three day Police motor school, on my own bike, and rode it back home. From there, my wife and I traveled to Gatlinburg TN last fall, and back, on the FLHRC. This spring, I rode my bike down to Orlando FL for bike week, and back. All on the same tire.
I probably practice once a week, for 90 minutes at a time, and on each long rode trip, I also install my tour pack. I also ride year round. So this tire saw road use in November, December, January and February, when the average temps were well below 40 degrees. The total gross vehicle weight with myself and my wife on the back, with the bike fully packed, total well over 1,000 pounds. At the 15k service, when the tire was installed, and the 20k service, when the tire was inspected, Chris, my mechanic inflated the tire up to 40psi, and told me to MAINTAIN this psi level at all times.
Harris, my motor instructor, who I respect more than anyone when it comes to Harley Davidson motorcycle knowledge, has been certified to train professional Police motor officers by the Harley Davidson motor company maintains the same psi level on his bike. Feel free to visit our group website
My training videos are pretty easy to recognize. All of these videos were filmed on this one, particular, tire. Thus, as you can see for yourself, this tire was put to the MAXIMUM use over its lifetime. I don't know how many times I have dropped my bike practicing and training over this time period, but I would say it is well north of 30. A couple of times, I've done a few 360 degree rear wheel spinouts practicing the Intersection. How many 18x36 foot figure eights have I done on this particular tire?? God only knows, but I would say HOURS upon HOURS. How many times have I run the brake and escape at 40+mph?? Dozens of times. Countless times. I won't even go into my hydroplaning, fishtailing, caught in the rain experience.
All of this, at 40psi.
Long post short, I RIDE my bike to the limit, 24/7/365. 11,000 miles later, I finally replaced this tire, with absolutely NO problems. No leaks, No nails. No punctures, No warping, No bumps, No failures, No nothing.
At the end of the day, it's your life, and it's your bike. Ultimately, you will do, what you want to do. If this post has not convinced your to inflate your tires up the maximum psi, then nothing will.
David
Old 04-28-2009, 10:28 AM   #13 (permalink)
FOG
trooper113's Avatar
I absolutely respect Harris and his instruction. I was a certified LE EVOC instructor for OHP in my previous life. In that training and on our patrol cars in daily service we ran maximum pressure. We weren't concerned with tire wear or comfort nearly as much as we were with sidewall flex and overheating which max pressure helps alleviate.
I still feel that for the average rider/driver doing NORMAL riding or driving, using specified air pressure to slightly over specified pressure gives the best overall results.
trooper113
AMA Member
Old 04-28-2009, 10:44 AM   #14 (permalink)
bc_hombre is on a distinguished road
it's funny how i can remember picking gravel out of my body 35 years ago when i grabbed my front brake on gravel. i was not wearing gear and had road rash from head to foot. for me, it is a natural response to hit the rear and a memory of my first accident that causes me to react this way. yesterday, i had to brake in an emergency situation and locked up the back wheel. stupid, stupid stupid! how to break this habit my lie in your post nazzdak. i need to hit the parking lot fully loaded and do dozens of break and turn maneuvers until i do it out of instinct. i am heading across the country next week and this is one area i need to work on. erc refresher i take in a couple of days. can i add one more rule of the road? when someone attempts to wave you thru an intersection, stop sign, parking lot, where ever, trying to be a traffic cop or just courteous, shake your head and refuse.
06 ultra
95" hillside build
103 torque
97 hp
TW26g
v&h pro pipes
k&n air
hog tunes amp plus 6 speakers
grateful dead sticker
bc_hombre is offline   Reply With Quote
Old 04-28-2009, 04:58 PM   #15 (permalink)
Draggin' Floorboards!
jpilone's Avatar
jpilone is on a distinguished road
This thread sounds like an advertisement for a book....
-Jarrod Pilone
Fort Lauderdale Harley Drill Team Member
'07 Ultra Classic E-Glide
Rinehart True Duals, SERT, Custom Airbrush Work,
31,300 Miles & Counting
Scrapin' Boards & Burnin' Clutches!
"It's the f'n Catalina Wine Mixer"
jpilone is offline   Reply With Quote
