Harleybeg-
Here is a link to the slow ride portion of the California DMV test.
http://www.youtube.com/watch?v=xI6uX...eature=related
The circle does not look THAT big. I'd say no more than 24 feet in diameter.
Here are some tips that should help you....
1. Practice, practice, practice!
You should be able to find a measuring tape and 45/9 inch orange soccer cones at your local Walmart for less than 50 bucks. Thus it will not be difficult or expensive to duplicate the California DMV test pattern. Make sure your circle is at LEAST 24 feet in diameter, and that your two approach and exit lanes are at LEAST 5 feet wide, and 20 feet long, apiece.
When you practice the slow cone weave, make sure your practice cones are at least 12 apart and that you focus on the LAST cone as you enter the exercise.
2. HEAD and EYES!
Remember to always look FAR AHEAD of the motorcycle. If you are entering the circle at, say, 5 o'oclock, and traveling counter-clockwise, then your head AND eyes should always be at least 15-20 minutes ahead of the motorcycle. Thus, your head and eyes should already be focusing on the 1-2 o'clock position as you're entering the circle. By the time your front wheel hits noon, your head AND eyes should be well ahead to 7-8 o'clock and so on.
3. Feather the rear brake 100% of the time.
The next time you ride your bike, do me a favor. See if you can "walk your bike." I would like to see you ride from point a, to point b, at idle speed, with your right foot on the rear brake 100% of the time without applying ANY pressure. This will give you the control that you'll need at the entrance and exit points. Your right hand should be completely wrapped around the handle bar grip as you should be ignoring the front brake completely.
4. Have you clutch adjusted immediately by your local dealer.
In the slow ride portion of the california DMV test, you're going to want MAXIMUM control of your motorcycle. This means that your clutch is most likely not set up properly. A standard HD clutch has three operating positions. Open-Semi closed- Closed. A Police bike has at least 4
1. Fully open
2. 1/3 closed
3. 2/3 closed
4. Fully Closed
Thus, tell your service dept. mechanic that you want your clutch set up to Police bike specs ASAP.
good luck!
David
