06-07-2008, 02:37 PM
Cabo Wabo '06
Horny
Just wondering..................how many of you ride your horn switch in street traffic, or any other traffic for that matter (it could help).
05' Deluxe EFI/BC Pearl
Build, blueprint, & fine tune
95" KB domed pistons (10.3 to 10.6 dyn.comp.)
.030" commetic/.035" quench
HD cyl's .001" piston fit
06' modded heads
B Diamond high lift springs
perf valve job (Boyd's)
TW55 chain drive cams
S&S adj. pushrods
SE heavy clutch diaphram spring
Hi comp A Balls starter
Rivera 10/84 Ring gear
polished TB/manifold
Doherty w/Power Vents
Pro Pipe HS header w/Cycle Shack Rocket tip muff.
PCIII & Dyno
Jagg oil cooler
93HP/98TQ
06-07-2008, 02:59 PM
killer sperm
There have been a few times I have covered the horn button when a nearby driver seemed oblivious, a couple times it has gotten their attention when I did blow the airhorn at them. When I do this I remind myself not to let the horn distract me from more important things. In really sketchy situations it seems there is no time to toot and it is doubtful it would help.
The BJ's Specialties airhorn instructions direct you to blow the horn at least once every ride to keep them limbered up. This helps the thumb to remember where the button is as well.
xxxxxxxxxxxxxxxxxxxxx
06-07-2008, 03:02 PM
I use my horn so rarely, I couldn't find it quickly if I needed to.
I give the pipes a quick rev if I want to let a guy know I am next to him, but other than that I just try to stay out of everybodies way.
06-07-2008, 03:10 PM
killer sperm
In a stressful situation it's easy to forget where the button is though it seems a fella can always remember where his middle finger is...
06-07-2008, 03:27 PM
The Sideshow
Horns on most bikes are worthless. I have found that the HD horns are a little louder than most, but theyre still worthless. I just act like everyone wants to kill me, that seems to work best. Last thing I need is some soccer mom getting pissed off at me because I honked at her. Her gay-ass Dodge Caravan is going to win over my bike everytime.
Dave
06-07-2008, 03:34 PM
Bwahahahaha! Funny how that works!
06-07-2008, 10:34 PM
I am in the habit of covering my horn switch when in city traffic. I use the Stebel Nautilus air horn and it has saved my butt on several occasions.
I too make sure to blow mine on every ride to keep it limbered up and to make sure it is working before I need it.
My thumb has more trouble remembering where the high beam switch is than the horn switch.
06-14-2008, 03:58 PM
I've tried to use my horn a couple of times when someone has or is trying to make a left turn in front of me. Every time I've only been successful in turning on my LEFT BLINKER which is exactly what I do not want to do. This just makes them think I am turning left too and they continue with their traffic maneuver.
I'm trying hard to remember that the thumb position needs to be higher if I want to operate the horn and not the blinker.
Maybe I should just practice driving around town and honk at every cage driver that is not paying attention to their driving. If I did that though I might as well wire the horn so it is blaring every time I'm in traffic!
08 Ultra Classic
06-14-2008, 04:09 PM
FOG
I just installed a Mini-Beast horn....a Stebel Nautilus in a nice chrome cover. Outstanding! Seriously loud and looks decent.
trooper113
NRA Endowment Member
AMA Member
06-15-2008, 09:49 PM
If my horn doesn't get their attention, (if their too close) my boot usually does!
07' Soft Tail Custom!
BASSANI Pro Street pipes...
Lowered || Carlini's || Custom Chromed controls || Braided Lines || Custom grips & Levers || Custom mirrors || Badlander seat || NightRider XiED's || Chromed rearend || more to come!
11-06-2008, 10:03 AM
LEOs have it right
My '05 RK Police has the stock controls and the horn button is actually elongated to make it easier to find in a hurry. Not finding the horn right away when it is really needed would suck!
11-06-2008, 11:44 AM
I have only had my bike for about 9 months. I never gave the horn much thought. I tend to do the same as "Faast Ed" and use the pipes. I have tested my horn a few times and the pipes are louder. I bumped my horn a few weeks ago to get a buddies attention before leaving a parking lot and it only made a gargling noise like it was under water. There had been no rain and my bike is garage kept so I'm sure it's not wet. I was told that the HD horns have an adjustment somewhere. Anybody know about this?
11-06-2008, 11:50 AM
I have never heard of an adjustment on a HD horn Skid. It sounds more like a grounding issue or a loose connection to me.....
2005 FSXTI
SE 95"
Andrews TW21 Cams
D&D Low-Cat Exhaust
SE Pro Race Tuner
11-06-2008, 11:56 AM
I didn't think so. I looked all over it and there is just not that much to it. I haven't made a real effort to try and fix it. The weather has been too good lately to waist time on a horn I don't use anyway.
11-06-2008, 12:14 PM
Actually, I took mine out cause I moved my coil to the former horn location.
Now, I plan to use the horn button for a nitrous switch!!
 Nowhereman who else?
