How to remove melted plastic from exhaust? : V-Twin Forum: Harley Davidson Forums
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > Motorcycle Related Discussion Groups > Motorcycle Care Products
Old 09-25-2006, 12:01 AM   #1 (permalink)
skippy49 wants to know Dino or Syn?
Dropped something on my exhaust a while back-can't remember exactly what now-but I think it was a plastic bag or something like that. Anyway I found the results on it when I got back from that trip and it appears to be something melted on it. I've been trying WD40 and a lot of soaking but haven't made a lot of progress so far-although it is getting better.
Any good suggestions for something to remove it with? All my cleaners & polishers didn't seem to do much.
skippy49 is offline   Reply With Quote Quick reply to this message
Old 09-25-2006, 12:05 AM   #2 (permalink)
SAFXDL's Avatar
SAFXDL is reading this now saying WTF is this?
I had some melted plastic on mine...I warmed the engine and used oven cleaner...then my chrome polish....it worked.
They call me Al....Big Al
Proud Parent of a Son serving his country
'08 FLHPI, 103, SERT, Fatcat 2/1 Black, Reckless Fairing w/tunes.
SAFXDL is offline   Reply With Quote Quick reply to this message
Old 09-25-2006, 12:12 AM   #3 (permalink)
I'll try that. I didn't have any oven cleaner but I'll get some and see.
Thanks,
Old 09-25-2006, 12:58 AM   #4 (permalink)
The Tourist wants to know Dino or Syn?
Something that is a softer abrasive works good while using the WD-40. I use something like 0000 steel wool, SOS Soap pads or Nevr-Dull.
Use asymetric circles when wiping, and do it gently, gently, gently.
The Tourist is offline   Reply With Quote Quick reply to this message
Old 09-25-2006, 03:36 AM   #5 (permalink)
professional doof
apache36's Avatar
apache36 wants to know Dino or Syn?
0000 steel wool and water.....tried and true....works for me every time i have some silly fender lizzard on the back who does exactly what i tell her not to do....."keep your damn feet off the pipes".....i bet i go through this ritual at least once or twice a month.
josh
apache36 is offline   Reply With Quote Quick reply to this message
Old 09-25-2006, 03:41 AM   #6 (permalink)
Sick Puppy
firetronix01's Avatar
firetronix01 wants to know Dino or Syn?
See;Nasty sh!t
Just remember, wherever you go, there you are.
Ex wifes preacher said"Yeah...I know, I'm going to hell."
95"
Street ported heads w/SE springs
9.6:1 SE high comp. forged pistons
ThunderHeader
Andrews 37G cams
ThunderVolt50 ign wires
Metzler tires
Progrssive suspension
the list goes on and on
firetronix01 is offline   Reply With Quote Quick reply to this message
Old 10-01-2006, 06:08 PM   #7 (permalink)
Markfatboy05's Avatar
Markfatboy05 wants to know Dino or Syn?
I melted my rain pants on mine, used oven cleaner, then "blue Job", some elbow grease, and it came off....good luck
Markfatboy05 is offline   Reply With Quote Quick reply to this message
Old 10-01-2006, 06:51 PM   #8 (permalink)
Lazy 98
Mike H.'s Avatar
Mike H. wants to know Dino or Syn?
Try acetone-- I use it all the time, and it smells and works great! (really- it dissolves most anything and doesn't scratch)
'06 Heritage Softail Classic
Heads by GMR
Revolution 98" w/CP flat tops @ 9.7:1(9.28 corrected)
Andrews 37G
Mikuni 45
V&H Propipe
SE clutch spring, Barnett disk pack
Hayden M6, LMRII oil spring
ProCharger
Mike H. is offline   Reply With Quote Quick reply to this message
Old 10-23-2006, 05:18 PM   #9 (permalink)
emirharley's Avatar
emirharley wants to know Dino or Syn?
It is simple like that: first use gasoline from your fuel tank, than Nevr-Dull Wadding polish (you must have it, since you will always need it!) and finally an old cotton T-shirt. Good luck.
emirharley
"Sarajevo Bikers Club" MC
www.sarajevobikersclub.ba
2001 Harley-Davidson Road King Classic FLHRCI HDI EFI
Screamin' Eagle Stage One Kit
RevTech DFO Stealth Performance System
Screamin' Eagle Performance Mufflers
(Set two: Wild Pig Pipes, 2" baffles)
Ape Hanger
Back Rest
Kuryakyn Spider Light
et cetera
emirharley is offline   Reply With Quote Quick reply to this message
Old 11-05-2006, 02:59 AM   #10 (permalink)
glaxo151 wants to know Dino or Syn?
Honda Pro spray cleaner on fine steel wool, wipe with clean rag.
glaxo151 is offline   Reply With Quote Quick reply to this message
Old 11-20-2006, 02:40 AM   #11 (permalink)
Phil9674 wants to know Dino or Syn?
Easy Off oven cleaner and a old rag but do not get any on paint or aluminum, you can use a razor blade on thick spots first. If you use steel wool you will leave fine scratches in the chrome. This has always worked for me. Phil.
2002 FLHTCI
95 SE flat tops
Street port heads
26G cams
Ness Big sucker
V&H Tru Duels with O2 ports
Supertrapp 4" Megs
SE Racetuner
Twin Scan II+ WB
Phil9674 is offline   Reply With Quote Quick reply to this message
Old 12-29-2006, 12:16 PM   #12 (permalink)
Liker of Mid 60's FLH's
ChromeWelder's Avatar
ChromeWelder wants to know Dino or Syn?
Unhappy Steel Wool...DON'T DO IT!!
Don't even think about putting any type of steel wool (don't care how fine it is) on any chrome surface you care about. I've been there and done that (bad plan).
Melt off what you can and and then get some "Goof Off"
http://www.drugstore.com/products/pr...Y-PLST-0-BRAND
Then use a PLASTIC dish scrubber (NO METAL) with the Goof Off after the pipe has cooled. There is no easy way to get that crap off. Just be patient..you'll be glad you did.
Near Ouray Colorado...June 2009
ChromeWelder is offline   Reply With Quote Quick reply to this message
Old 12-29-2006, 01:45 PM   #13 (permalink)
Just happy to be here
Freeway wants to know Dino or Syn?
A piece of scrap wood works for me. Heat the pipes up and scrape it off. Wood's softer than chrome, so no scratches.
Alcohol, Tobacco & Firearms should be a convenience store, not a government agency.
Freeway is offline   Reply With Quote Quick reply to this message
Old 12-29-2006, 01:52 PM   #14 (permalink)
SLOWHOUND wants to know Dino or Syn?
I used Flitz on my FXD Propipe,coming back from TX. I got some plastic rain suit on them(they are out of here)and used Flirz witha shop rag all gone and shiny chrome.
SLOWHOUND is offline   Reply With Quote Quick reply to this message
Old 12-31-2006, 01:53 PM   #15 (permalink)
Seasonably Uncool
Sponk's Avatar
Sponk wants to know Dino or Syn?
Hi!
I got some goop on my pipes and got rid of most of it using chrome polish. The rest I can't seem to get off "mechanically", so I think I'll have to go chemical.
A lot of guys here have been recommending Easy-Off oven cleaner. The can I found here at the house ("Easy-Off Heavy Duty Original Oven Cleaner") says on the label not to use it on chrome, though. Is it safe to use anyway? Or are there different kinds of Easy-Off? Don't want to make bad worse...
Sponk
Love- the feeling you get when you like something as much as your motorcycle.
-Sonny Barger
crashing sucks
Sponk is offline   Reply With Quote Quick reply to this message
