06-21-2009, 10:29 PM
What to use to get melted raingear off pipes
What can I use to get melted pvc raingear off pipes?
"To sit back hoping that someday, some way, someone will make things right is to go on feeding the crocodile, hoping he will eat you last - but eat you he will." – Ronald Reagan
06-21-2009, 10:35 PM
Audentes Fortuna Juvat
use oven cleaner on hot pipes!! However, DO NOT spray it on the pipes. Spray it on a rag and wipe the hot pipes with it. The reason I say dont spray it directly on the exhaust is the over spray will ruin the finish on the motor, paint, etc...
2007 FXSTB
Friedrich Nietzsche
I'm Your Huckleberry
mayhaps wd-40 ??
The Fair Tax- (go ahead, click it.)--
'07 Ultra -> Covington, Ga.
06-21-2009, 10:46 PM
I haven't seen your bird.
Give GooGone a try.
03 XL1200 Custom
06-21-2009, 10:52 PM
Keep the rubber side down
Works, great, but I found out the hard way. Like he said, spray on a rag or sponge first.
04 E-Glide Standard
95" Big Bore
SE A/C
V&H Pro Pipe HS
06-21-2009, 11:08 PM
The Sideshow
Just make sure that the sponge is not plastic (some are). It will melt to the pipes. Don't ask me how I know.......
Dave
2008 FLHRC
Rinehart True Dual Exhaust System
Arlen Ness Big Sucker Intake
Super SERT Dyno Tune by HD of Montgomery, AL
06-21-2009, 11:44 PM
Road rub
is the best thing i have ever used for melted boot rain gear.
it takes just about anything off
07-12-2009, 02:29 PM
Get some .000 Steel Wool and it will take the marks off your pipes, and at the same time, polish them.
07-12-2009, 03:25 PM
Since mine don't have heat shields eventually the rain gear meltage just burns away.
Tom S.
The American people will never knowingly adopt Socialism. But under the name of 'liberalism' they will adopt every fragment of the Socialist program, until one day America will be a Socialist nation, without knowing how it happened. Norman Thomas
"...and Socialist governments traditionally do make a financial mess. They (Socialists) always run out of other people's money. It's quite a characteristic of them." Margaret Thatcher
07-12-2009, 03:53 PM
Another vote for the oven cleaner.
Ride what you like, like what you ride
1997 FLSTC
"Hanging in, Hanging on, Hanging out"
07-12-2009, 06:42 PM
"3 feet high'n rising..."
I'll second this one...
2008 FLHT, V&H Duals (16737), V&H Ovals (16727), V&H Fuelpak (61009), SE A/C (29260-08), Andrews 26H Cams (216326).
07-13-2009, 01:22 AM
Iron Steed
In addition to oven cleaner...
...I have used alumnium foil behind the pipe I am cleaning and to cover any parts below where I'm cleaning...creating a sort of gutter for runoff down to the ground away from the bike. Even with a sponge or rag, it will drip and spatter every so often. You don't want that stuff on your paint. Good luck!
Cheers,
-JB
"Dream as if you'll live forever, live as if you'll die today." - James Dean
08-03-2009, 10:02 AM
I have used, very successfully, the oven cleaner that is designed to be used on COLD ovens. I used it on cold pipes and I left it on over night and the melted rain gear slid right off with no damage to the pipe.
Then I had the wife sew a piece of black denim on the inside of the right leg of the rain gear. This covers up the damaged area and prevents it from happening again.
Bob
08-03-2009, 10:28 AM
.00 steel wool and windex works well. The .00 steel wool will not scratch and polishes the chrome at the same time with very little effort. Windex will not affect any other finish it comes in contact with. The same process can be used on the windshield of vehicles as well.
AZ Cajun
08-03-2009, 10:56 AM
when that happened to me ..... I took the pipe off, took it outside the garage and sprayed oven cleaner on it and let it sit over night .... it took two applications to get it all off...
if you do this on the bike, DO NOT get it on painted surfaces !!!
spray it on a rag first, then wipe it onto the pipe, never spray that stuff towards your bike ....
