Massive 2009-2010 Harley recall : V-Twin Forum: Harley Davidson Forums
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > Technical Discussion Forums > MOCO Service Bulletins
Old 12-10-2009, 12:39 PM   #1 (permalink)
DrumScum wants to know Dino or Syn?
Harley announced yesterday they are recalling over 111,000 2009-2010 Touring family motorcycles including cvo and trike products. The recall involves the front gas tank mounts. Dealers will have add a brace to strengthen the mounts which are said to possibly distort and cause a fuel leak in a frontal crash leading to fire and possible serious injury. Looks like numerous models are affected.
DrumScum is offline   Reply With Quote Quick reply to this message
Old 12-10-2009, 12:58 PM   #2 (permalink)
I haven't seen your bird.
MadCity's Avatar
MadCity is reading this now saying WTF is this?
Here's a story about it in Milwaukee's Business Journal.
03 XL1200 Custom
MadCity is offline   Reply With Quote Quick reply to this message
Old 12-12-2009, 10:26 PM   #3 (permalink)
z06
z06 wants to know Dino or Syn?
Dealer called this afternoon and said that the parts came in today and that my new Street Glide has had the modification and will be read for pickup this coming Wed went all of the other Acc are installed. Will take a picture of the mod when I get the bike and pass it on if someone else doesn't. The dealer says that they are getting .3 hrs for install. He said it was very easy and you can't even see it. I will have to make that judgment. He says it appears to be plastic. We will see.
z06 is offline   Reply With Quote Quick reply to this message
Old 12-13-2009, 12:01 AM   #4 (permalink)
dortiz64's Avatar
dortiz64 wants to know Dino or Syn?
fuel tank recall done on my 2010 Glide
had the fuel tank recall on my 2010 Glide.....it is a plastic reinforcement piece that goes between the frame and the tank's bolt that holds tank to frame. Reinforcement plastic is not noticeable and it also has a rubber cover...no big deal
dortiz64 is offline   Reply With Quote Quick reply to this message
Old 12-16-2009, 10:54 PM   #5 (permalink)
2006xl1200's Avatar
2006xl1200 wants to know Dino or Syn?
I work at a dealer and they dont change the lift of the tank any at all.It is just basically a hard plastec pice that goes behind the front fuel tank mounting hole and bolt againts the frame and also a rubber cover that goes on the tank tabs.It just helps in the absortion if distoron would occur.They are doing wave shipments of these parts meaning that each dealer gets a certain prectange of whats affected they sold.Every dealrer vaires based on sales.Some may get 6.We got 20.
2006 XL1200C with S/E Heads,551 Cams,Perfect Fit Pushrods,Cylinder Studs,42MM Mukuni,Manifold,Clutch,Igintion Module,Plugs,Wires,Arlen Ness Big Sucker,Vance and Hines Shortshots Staggered and the rest of the bike chromed out!
2007 FXSTC with S/E 110 Heads,103 Cylinders,Pistons,Adjustable Pushrods,58MM Throttle Body,Manifold,Heavy Breather,Plugs,Wires,S&S 585C Cams,Zippers ThunderMax,Vance and Hines Big Shots Staggered and the rest of the bike chromed out!
2006xl1200 is offline   Reply With Quote Quick reply to this message
Old 12-22-2009, 08:10 AM   #6 (permalink)
Winter SUCKS
harleymike77's Avatar
harleymike77 wants to know Dino or Syn?
My bike was already at the Dealers when I received notification. They advised they will just keep it until the part comes in. They have no ETA at all, but are thinking late January. Kindda hard to ride with all the snow on the ground anway. Almost looks like I may get "free" winter storage" out of this recall........
2014 FLHTK - Ultra Limited 91.51 HP 106.72 TQ
Andrews 57h Cams/Timken bearings/SE Adjustable pushrods/2-1-2 Headpipe/SE Chisel Extreme Billet Air Cleaner/4" Rineharts/SEPST
Chrome front end/inner primary/Mirror Chrome Slicer Wheels with chrome rotors & calipers/LED Lighting/Braided lines/Corbin Dual Tour Saddle, TP and backrest/Premium Ride Hand-Adjustable Touring Shocks/Front Lowering Kit
harleymike77 is offline   Reply With Quote Quick reply to this message
Old 12-28-2009, 08:02 AM   #7 (permalink)
t-town bernie wants to know Dino or Syn?
got my recall notice 3 days ago ill have them install in a couple of days when they install and dyno the super tuner on my FLHTC
t-town bernie is offline   Reply With Quote Quick reply to this message
Old 01-08-2010, 10:46 PM   #8 (permalink)
acchd wants to know Dino or Syn?
Kinda surprised the dealer called me to bring it in and ask if I'd got the letter.
acchd is offline   Reply With Quote Quick reply to this message
Old 01-08-2010, 11:21 PM   #9 (permalink)
autoworker's Avatar
autoworker wants to know Dino or Syn?
No big deal.I had mine done over the holidays.
autoworker is online now   Reply With Quote Quick reply to this message
Old 01-22-2010, 07:56 PM   #10 (permalink)
flapper04 wants to know Dino or Syn?
recall 09-10 touring models
Does anyone know if they have to remove the gas tank to install this plastic reiforcement piece
flapper04 is offline   Reply With Quote Quick reply to this message
Old 01-22-2010, 08:15 PM   #11 (permalink)
Just Wanna Ride
kingsoftail wants to know Dino or Syn?
Had mine done a couple of weeks ago. They do not have to remove the tank to do the repair. Loosen the rear tank bolt, remove the fronts, sightly raise the front of the tank and slip in the reinforcing piece. Re-tighten bolts - done. Took about 10 minutes. It took the dealer longer to do the paper work than the repair.
kingsoftail is offline   Reply With Quote Quick reply to this message
Old 06-24-2010, 03:35 PM   #12 (permalink)
salectric3 wants to know Dino or Syn?
had the recall on my 09 streetglide. It's 2 plastic filler blocks that go between the gas tank mounting tabs and the frame . Took me about 15 min. to install.
salectric3 is offline   Reply With Quote Quick reply to this message
Old 03-30-2011, 05:12 PM   #13 (permalink)
Gator454 wants to know Dino or Syn?
Thanks, been to the dealer and they installed the fix in about 15 minutes.
Gator
Gator454 is offline   Reply With Quote Quick reply to this message
Old 05-16-2011, 11:20 PM   #14 (permalink)
Jeff Dodson wants to know Dino or Syn?
WOW. I had a frontal crash and mine didnt catch fire
Jeff Dodson is offline   Reply With Quote Quick reply to this message
Old 06-01-2011, 07:22 AM   #15 (permalink)
Thanks for the heads up!
