passengers
You must tell them when to get on/off...Mounting is done {when you are ready} with the passenger stepping on the near peg, using your shoulders to steady themselves and step over the seat to the other peg. When dismounting {again, when you are ready} they use your shoulders to steady themselves as they stand on the pegs, then swing a leg over to the ground. Problems will occur with the passenger getting on/off when you are not ready.
...Once your mounted up, detemine where/how they will be holding on, consider acceleration and braking. Then go do some figure 8s, with the passenger LOOKING over your inside shoulder. You must tell them "simply, look over my inside shoulder when we are turning, NO leaning".
...With a good passenger you will only notice the extra weight. Close the throttle a bit sooner and don't tailgate at all. The last thing you want to do is scare them.
Be sure they are dressed to ride.
