I took a look at the microfische at the Honda dealer.
In a nutshell, to set up the Fall Away, remove all controls, top of tree, headlight & wiring. Make sure there is no restriction on the turning radius of the forks. Loosen top (lock) nut. Tighten bottom nut until firmly seated at about 15'# of torque. Swing forks back and forth a few times to make sure the bearing is seated. Retorque to 15'#.
Place lock ring on, bend tabs down. Replace top nut finger tight, but go to next tab position at 90* from bottom nut tabs.
Tie a string around each fork. Centre wheel. Attach a small "pull-scale" (kind of like a miniature fish scale) and pull forwards until forks fall to opposite side that scale is attached to. Minimum should be 0.95'#. Maximum should be 2.3'#. Do the same for the other side.
That is all fine and dandy, but I can't seem to get to the step where the wheel should be balanced in the straight ahead position. It always flops to the left. And the nut is tight and nothing is pulling it that way. There is no slack in the steering head bearings. Would the added weight of the brake and rotor make it fall that direction? If so, then how do I get to the point where the wheel is balanced, or do I take the pull test from the position where the wheel is not in the straight ahead position, but in it's balanced position, which is turned to the right a couple of inches?
I gotta get this done before Sunday. We are taking a 200 mile trip to help celebrate our friends' 50 Anniversary and if the wife's bike ain't ready, I'm as good as dead.
