Heavy Magic,
You are reading too fast, he means HE is doing his first oil change, not the bike's first oil change. read it s l o w l y "Dealer did an oil change (or so he says, anyway) about 1,000 miles back."
course, doing oil change every 1,000 miles is about as much sense as every 22,000 in my opinion, but hey, it is his bike, he can do what he wants and there is probably nothing to do down there on boring Aussie weekends
Stonep,
Re, your question: I'm sure there is a thread on this forum (search, search, search) that explains that this is to be expected from the primary case as the flecks will be from the clutch discs grinding away. There is no filter, so where else will they go, either from the clutch pack or any chain wear & tear? The plug is magnetic (somebody will correct me if it's not) so if you only "have a small amount of fine metal flakes" as you said, after 1,000 miles, you are good to go.
As for the color, I don't believe you will ever get the oil to stay in an as new color state. Only time you get that is in a clean fuel burning engine like LPG or propane.
Get out there, ride & enjoy the Aussie countryside, beach, desert, wherever you ride,
Jon
