Pro PadJardineProducts.comAmerican Side Road CycleBikeBanditSportbikeTrackGearCustom DynamicsLeslie Kay'sMotorcycle-Communication
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > Other Items of Interest > *HOT TOPICS*
JardineProducts.com
Old 07-06-2007, 05:53 PM   #1 (permalink)
oldscoots is on a distinguished road
Slipping Ape Hangers
Hey Gang,
With the recent popularity of Ape Hangers, I am sure someone else has experienced this.
I just installed a set of 13" on my bike with stock 1.5" risers and the stock top clamp. I tightened down the top clamp and used Blue locktite on the allen head bolts. I have the bars positioned slightly forward of the fork tube angle.
After hitting a couple of bumps, the bars start sliding backwards towards me.
I took the bars off and took a center punch and roughed up the riser inside surface as well as the inside surface of the top clamp. This still did not cure the problem.
I see guys running 18" Apes and I know they generate more leverage to potentially cause the bars to move and no problems.
How do I fix this? The risers are used takeoffs but look OK for the most part.
oldscoots is offline   Reply With Quote
Old 07-06-2007, 06:41 PM   #2 (permalink)
Lightnin is an unknown quantity at this point
Wish I had a good answer for you. I have 12.5" apes that are knurled but when I hit an unavoidable bump/road divot, they'll pull back too. I just push them back. I figure by the time the knurl in that spot wears out and won't hold during normal riding, I'll be tired of them and switch to different size apes.
Sorry, not much help...I know
Lightnin is offline   Reply With Quote
Old 07-06-2007, 08:39 PM   #3 (permalink)
baggersport's Avatar
baggersport is on a distinguished road
Using the center punch is a good thing when they aren't knurled. Make sure you tighten on the stock risers by the book, you may have a washer type boss on one side of the top clamp and I think you tighten that side first. You might try coating the clamping area with some green Loctite (bearing and sleeve retainer).
www.bigboyzheadporting.com
Big Boyz Street Heads
207-242-8374 Cell Phone
207-621-8089 Port/Dyno Shop
baggersport is offline   Reply With Quote
Old 07-07-2007, 01:48 AM   #4 (permalink)
Goin' Fast with Class
seamonkeyman is on a distinguished road
I cut a beer can up into strips. Wrap them between the bar and clamp then tension. No slipping whatsoever.
First time the bars slipped I was a fair ways from home and had to ride bike back with loose bars. Not a wise move....
Good Luck
2005 FLSTNI
95BB/Flat Tops/SE203cams/SE Air cleaner,
BigBoyz Street ported '00 heads with 82CC chambers, 9.5:1CR, .030 Cometic, 3.37 gearing,
LSR002 Spring, Thunderheader, SERT. Seat of Pants dyno only and always looking for a better SERT MAP!!
seamonkeyman is offline   Reply With Quote
Old 07-07-2007, 06:21 AM   #5 (permalink)
EASY DOES IT
swmnkdinthervr's Avatar
swmnkdinthervr is on a distinguished road
Go to a hardware/plumbing supply/home depot and get some emery cloth (sand paper to clean copper with) cut to size and I'll bet they won't move anymore...
“Any society that would give up a little liberty to gain a little security will deserve neither and lose both.” Benjamin Franklin
My pics
'04 Springer Softtail, 98" Nikasil
swmnkdinthervr is offline   Reply With Quote
Old 07-07-2007, 03:08 PM   #6 (permalink)
Thanks for the ideas.
I second that motion, riding home with slipping ape hangers is the worst!! A literal pain in the neck/back.
The bars are knurled but the risers have some "mileage" on them. Maybe the worn tolerance needs shimming up i.e. aluminum strips or emery cloth.
I'll try and update with results.
Thanks again!
Old 07-07-2007, 06:27 PM   #7 (permalink)
Otto is on a distinguished road
you did it backwards use the center punch and punch the bars so the bars bite into the riser lunim just pushes away if you punch the riser
Otto is offline   Reply With Quote
Old 07-07-2007, 08:01 PM   #8 (permalink)
Thanks Otto,
The bars are already knurled though. They are Flanders, so nicely done.
Old 07-08-2007, 10:00 AM   #9 (permalink)
ridingcoreman is on a distinguished road
Thats what I did.No more slipping.It doesn't take a very big piece.
03 Fatboy
ridingcoreman is offline   Reply With Quote
Old 07-08-2007, 10:22 AM   #10 (permalink)
OK,
So I am going to try the emery cloth option first. Will update on results.
Thanks again!
Old 07-27-2007, 11:10 PM   #11 (permalink)
Logged a few hundred with no bar slippage at all.
Got some emery cloth from Home Depot, trimmed to fit width of knurled section of bars, installed, no problem.
Thanks guys!
Old 07-30-2007, 01:46 AM   #12 (permalink)
FYJIGM
DNLEVESQUE is on a distinguished road
I used emory cloth also on mine and no more slippage. Thanks for the idea swm.
05 Chopper Blue/Brilliant Silver Springer Classic
V&H Big Shot Staggered exhaust
Ness Big Filter
98" RevPerf BB kit
37g cam's
DTT ignition
Heads CNC'd by GMR
Mik 42 carb
LMR-2 oil spring
SE Diaphragm Spring
VPC 92T
SE intake manifold
DNLEVESQUE is offline   Reply With Quote
Old 08-01-2007, 04:08 PM   #13 (permalink)
EASY DOES IT
anytime bro...it's a reall bummer when yer goin' into a turn and the bars move as you lean!!!
My pics
Old 08-01-2007, 04:24 PM   #14 (permalink)
mcbean7 is on a distinguished road
Originally Posted by oldscoots
OK,
Thanks again!
I've been experiencing the same problem with 14" apes. I'll try this emery cloth too. Thanks for the idea guys.
mcbean7 is offline   Reply With Quote
Old 08-01-2007, 11:20 PM   #15 (permalink)
FYJIGM
I'm glad it never did it on a turn but even when not on a turn it'll make you pucker up.
Ness Big Filter
98" RevPerf BB kit
37g cam's
DTT ignition
Heads CNC'd by GMR
Mik 42 carb
LMR-2 oil spring
SE Diaphragm Spring
VPC 92T
SE intake manifold
